Domoboard - Configuration issues
Domoboard is a dashboard for Domoticz based on Python Flask.
Moderators: leecollings, wez3
Forum rules
Before posting here, make sure you are using the latest Beta or Stable version.
In order to fix issues or add features these have to be reported on the Domoboard Github pages.
This makes it possible to keep track of issues/features on a centralized place.
Refer to the issue of the github tracker when possible.
This subforum is meant to discuss issues and/or feature requests, or anything else related to Domoboard.
wez3
Post by wez3 »
This topic is used to discuss issues during configuration of Domoboard.
wez3
RFAH
Domoticz version: 3.6395
Re: Domoboard - Configuration issues
Post by RFAH »
I want to add the venetians blinds to domoboard.
Their type in domoticz = RFY, sybtype = RFY. (They are controlled by RFXCOME)
I have tried the selector switch as i understand that the selector switch can show several buttons for up, stop and down.
However, no buttons are shown.
Are venetians blinds supported if their type is RFY?
Or did i choise the wrong switch?
Part of the config.
    [[[Raambedekking]]]
      Duette = 81, selector
      Screen = 107, selector
Thanks in advance
Awst6000
Post by Awst6000 »
Here a similar situation. This did work in the past:
[dashboard]
[[display_components]]
components = top_tiles[1], top_tiles[2], top_tiles[3], domoticz_smart_charts[1], domoticz_smart_charts[2]
[[top_tiles]]
[[[1]]]
(Items that are not relevant for this question)
[[[2]]]
Rolluik woonkamerraam = 126, blinds (But now I only get a dash as status)
Rolluik slaapkamerraam = 135, blinds (But now I only get a dash as status)
Scherm boven balkondeur = 151, blinds (This one does work)
RFAH
Post by RFAH »
Hi Awst6000,
In the top-tiles, the status of my blinds are still shown.
I'm using the latest version of the master-build, not the developers build. (Domoboard "says" hurray! There is no update available for Domoboard).
Also i'm not using the word blinds behind the xid.
Maybe that's the difference.
My problem is that i cannot control the blinds using Domoboard, only show the status.
squandor
Domoticz version: 3.5837
Post by squandor »
RFAH wrote:Hi Awst6000,
That sounds actually logical because the switche types blinds and RFY are not yet implemented/developed
Awst6000
Post by Awst6000 »
@Squandor:
But why do I see for 2 Somfy blinds only a score (-) and not the actual status?
This did work before.
I have another question:
Can the fontsize of the status of the top_tiles be adjusted?
Txs!
Awst6000
Post by Awst6000 »
I wanted to install Domoboard on a testmachine.
So first I installed the Github software.
After that I cloned Domoboard, but the Plugin page is empty.
What went wrong?
htilburgs
Post by htilburgs »
Domoboard is running OK, but after installing Afvalkalender, Domoboard won't start.
When I remove the files afvalkalender.py & afvalkalender.pyc, Domoboard starts again.
I've tried several things, but nothing works.
Tips??
Hardware:
squandor
Post by squandor »
htilburgs wrote:Domoboard is running OK, but after installing Afvalkalender, Domoboard won't start.
Tips??
Do you get an error in you're command prompt or console.log? and do you have the right settings in you're config.
If you enable afvalkalendar you must add something like this to you're config:
[[afvalwijzer]]
   zipcode = <zipcode>, <housenr>
htilburgs
Post by htilburgs »
Sorry for the late reaction. I didn't get an e-mail that there was an update. I hope I changed it now ;-)
I've deleted the afvalwijzer. Now I've installed the afvalwijzer again through Domoboard and it won't start, error:
Error occured during loading imports for the plugin afvalwijzer: No module named BeautifulSoup. Install it with 'easy_install BeautifulSoup' or 'pip install BeautifulSoup'
Hardware:
squandor
Post by squandor »
htilburgs wrote:Sorry for the late reaction. I didn't get an e-mail that there was an update. I hope I changed it now ;-)
Than you need to install Beautifulsoup using the provided commands
htilburgs
Post by htilburgs »
Strange, but...
I've installed BeautifulSoup, I've added Afvalwijzer and now I've found out what the failure was.
When you go to settings - plugins and click on afvalwijzer, the next text is displayed:
Afvalwijzer v0.0.2
Description
Small plugin which uses the site mijnafvalwijzer.nl to show which garbage will be picked up on which date, you configure this plugin by adding the following to an configuration: [[afvalwijzer]] postcode = zipcode, housenr
Summary
To use this plugin on you're dashboard you first need to check if you zipcode is in the mijnafvalwijzer.nl site. so check this first before you configure you're .conf file.
[afvalwijzer]
components = afvalwijzer
[[afvalwijzer]]
zipcode = xxxxXX, 11
Author: Squandor
I used regarding the description [[afvalwijzer]] postcode =
That is wrong and have to use zipcode =
So the eror went away, but now it says "zipcode not found"
I've entered zipcode = 5654KJ, 6
Is this the wrong format (tried several notations, but all the same error).
Hardware:
squandor
Post by squandor »
htilburgs wrote:Strange, but...
Afvalwijzer v0.0.2
Description
Summary
[afvalwijzer]
[[afvalwijzer]]
Author: Squandor
That's the right notation. But if I trie to use you're zip code on http://mijnafvalwijzer.nl it doesn't give an result so afvalwijzer doesnt support you're zip code
Snowtiger
Domoticz version: 4.10915
Post by Snowtiger »
I tried to get 2 temperature charts on one page with
[temperatuur]
 components= domoticz_temp_charts[1], domoticz_temp_charts[2]
[[domoticz_temp_charts]]
[[[1]]]
Temperature = 55, day, temp
[[[2]]]
Gevoel = 56, day, gevoel
Result - 1 line chart with 1 line the 'Gevoel' line , with twice Temperature in the label part, both with a different line
squandor
Post by squandor »
Snowtiger wrote:I tried to get 2 temperature charts on one page with
[temperatuur]
[[[1]]]
[[[2]]]
That's right because of the globals in domoticz you can only have one chart of the same category like day if you change the second chart to month it should work
Snowtiger
Post by Snowtiger »
[temperatuur]
[[[1]]]
[[[2]]]
Oké, thx - switched the 2nd to a normal line chart.
It is not possible to get 2 variables in one chart in Domoticz, and so in Domoboard?
squandor
Post by squandor »
Snowtiger wrote:
[temperatuur]
[[[1]]]
[[[2]]]
Actually bar chart and donut charts does support multiple devices
PSYCHOTIC
Post by PSYCHOTIC »
First off all thiz iz a superb frontend 2 use, far nicer than the other frontendz ive seen!!! Keep up tha good work.
It maybe me doing something wrong i can add tempgraph's but i dont know how to put voltage graph's. If i use temp or something else the graph remains enpty.
Thx for your time,
P.S.Y.C.H.O.T.I.C.
wez3
Post by wez3 »
PSYCHOTIC wrote:Hi,
Thx for your time,
P.S.Y.C.H.O.T.I.C.
Try this for an Voltage graph:
[[domoticz_counter_charts]]
[[[2]]]
ESP8266 Zonnepaneel Load V = 194, day, Voltage
PSYCHOTIC
Post by PSYCHOTIC »
THX Man!!!!
