I just added a Z-Weather sensor and it works properly. But I have a problem. I would like to make a script where I get a notification when the wind value is too high and make other things. But on the sensor tab there are multiple values like temperature, Wind direction, etc. How can I make it possible to only print the value of the wind speed and not all the values?
Thanks for your help
Z-Weather only wind value
- gizmocuz
Re: Z-Weather only wind value
You can't.... it plots the values it supports
from the openzwave control panel, do you see wind speed there ? Does it support even wind speed ?
Mikey
It shows all the values. And I know, that it always shows all values. But how could I remove characters from the data string that only the wind speed remains? Do you know how I could remove all the other characters except the wind speed?
