Tried including a Qubino (flush 2 relays) to a Z-Stick Gen 5. Tried it manual by removing the Z-Stick from my Rapi3. After pressing the button on the Qubino the Z-stick confirms with quick blinking and after that a steady light for a while. Then I shut down the Z-stick an plug it in to the Rapi: noting to see in Domoticz. I got 4 nodes intalled and working allready.
Secondly i try to add the Qubino from Domoticz by enabling "add sensor". A pop-up screen appears telling me to push the button on my Sensor. But when I do so, nothing happens.
What can I do to include this switch, or what am I doing wrong?
Promblem including switch
- Egregius
- Domoticz version: v2024.7
Re: Promblem including switch
Try to first exclude the device, before including it again.
Henk
- Domoticz version: 2020.2
OK Egreius, thank for your reply.
Tried the step-by step manual by Aotec like shown below. All light responses react like they should do. But still, after pluging the stick back in the rapi there is no change in Domoticz after a refresh...
Any ideas?
First Do an Exclusion or Unpair to a Z-Wave device (this also factory resets products)
This ensures that all the network information in a Z-Wave device is completely wiped, this should be done after every failed inclusion process, or before you add a new device.
1) Press and hold down the Z-Stick Gen5 button until it blinks yellow rapidly
2) Tap the button on the Z-Wave device you want to factory reset
The LED on the Z-Stick Gen5 should confirm a successful factory reset on a Z-Wave device by become solid blue.
3) Now tap the button on the Z-Stick Gen5 to take it out of exclusion/unpair mode
Now pair/include the device to your network
You've ensured that the Z-Wave device you want to add is completely factory reset, try pairing the device to your network.
4) Tap the Z-Stick Gen5 button, the LED should now blink blue
5) Tap the button on the Z-Wave Z-Wave device that you want to add.
The LED on the Z-Stick Gen5 should blink blue rapidly for a bit, then become solid blue if successful, or solid red if unsuccessful.
If unsuccessful, return to step 1.
Otherwise, you have successfully paired your Z-Wave device to your Z-Stick Gen5 network.
Any ideas?
