Philips HUE Motion Sensor
- constapel
Re: Philips HUE Motion Sensor
How do you feel about one more decimal value in temperature measuring:?
Your implementation:
My old implementation ( with time update lua script) ( asking too much system resources)
Jordy
Good point on the temperature. The value was not converted nicely (so it was rounded to a whole number), I fixed that. Sadly Domoticz will only show 1 decimal and not two. I hope that's ok.
As for the Lux part: The lightlevel itself is not in lux. So I added a conversion to lux (as indicated in https://developers.meethue.com/document ... ed-sensors chapter 2.7.1 Typical light levels for indoor use cases).
I'm not really satisfied with the default names (and apparently they are not updated by the Philips Hue app). So expect names like: ZLLLightLevel Hue ambient light sensor 9 and ZLLLightLevel Lux Hue ambient light sensor 9. You can trace it back to which sensor it belongs by fetching a full config from the bridge and search for the name and then check the "uniqueid": "00:17:88:01:02:00:AA:BB-02-0400" (minus the 02-0400 part). Then search again with the uniqueid.
Will create a pull request soon, so you can expect an update today or tomorrow
Preview:
Preview:
- Lux_and_temp.png (135.12 KiB) Viewed 7825 times
- constapel
Great!
This was my lua script to get the lux value:
But now its obsolete because i can use your implementation.
Thanks Again.
function My.LeesSensorsLux(t)
huestring = tostring(table.concat(t))
obj, pos, err = json.decode(huestring,1,nil)
if err then
print ("Error:", err)
if (obj.name) then
hue_name = (obj.name)
hue_lux = (obj.state.lightlevel)
hue_lux = hue_lux /100
if Debug=="YES" then
print (hue_lux)
return hue_lux
endThanks Again.
Jordy
I see that you just deviced the lightlevel by 100. The calculation to lux is slightly different: 10^(lightlevel -1/ 10000).
To be sure check the table in https://developers.meethue.com/document ... ed-sensors chapter 2.7.1
gingercat
Now got the latest beta with this support added - thanks for your hard work. My only query is should I expect ~5s delay for any triggers? I've got a bash script that turns on the lights in a particular order, with a short delay between each, but when walking into the hallway, it takes far too long for anything to happen.
Dropshot
I've updated to the beta version to be able to use the motion sensor, but now the LUA scripts don't update my virtual sensors anymore. Does anyone have the same issue/have a solution for it?
-- Update --
I found out that the method I used to update my sensors didn't work any more.
This one doesn't work anymore:
This one does work:
-- Update --
commandArray[#commandArray + 1]={['OpenURL']="http://"..localhost.."/json.htm?type=command¶m=udevice&idx="..idx.."&nvalue=0&svalue="..tostring(data) }Code: Select all
commandArray[#commandArray + 1]={['UpdateDevice'] = idx .. '|0|' .. tostring(data)}
Jordy
@gingercat worst case it could be 10 seconds. That is currently the 'default' poll interval. I'm not sure if you can adjust that interval.
scottydj2
I've added a change in the latest beta to allow the poll interval to be configured from the hardware devices screen.
Cheers
Scott
Cheers
Scott
Dropshot
Great! Thank you.scottydj2 wrote:Hi,
Cheers
Scott
Question: default is '0', what interval is used then?
scottydj2
If 0, the existing default 10s is used.Question: default is '0', what interval is used then?
Cheers
Scott
Off112
I'm new to Domoticz and trying to get my philips hue motion sensor to work with domoticz.
I have just installed the latest beta and and can se my devices. But there is no values. Lux and temp is 0 and motions sensor is always off. What have I missed?
UPDATE: I solved it. For some reason was the motion sensor deactivated in the Philips hue app.
/Arild
/Arild
Benneton
I have this sensor installed today. I can see it in the Philips App and after upgrading to Beta program of Domoticz I can see it in Domoticz to.
I made a little script to switch lichts in the hal to 15% when it is "dark" according to the light sensor and there is motion detected.
I hope it will override my time switched Hal lights so it will go from 5 to 15% when motion is detected and when lights are off due to time schedule they will light up when motion is detected.
Problem I have, must not understand it fully, is that the philips Hue App also switches the lights which it should not. I just want Domotizs to rule.
How do I set it up in the Hue App?
In the App I have Accessoire configuration --> There I have the sensor, switched on (when I switch it off Domoticz does not see it)
I tried to make a room with no lights in it but this I cannot select in the sensor.
What do I need to set to enable Domoticz to 'see' the sensor and bridge/app not taking any action
UPDATE: I have I believe worked it out, in the Hue App set Day, Night and Motion to TAKE NO ACTION.
Thanks for the support,
Bernard
A super great piece of work this Domotizs!
Bernard
gingercat
Thanks for this - will give it a try.scottydj2 wrote:Hi,
Cheers
Scott
Mazzokun
Hi all! I have Domoticz beta 3.8144.
Is Hue ambient light sensor broken?
Because HUE lux is 14444 but the light sensor is always On even with 4 lux.
Thank you
Thank you
sion
Hi guys.
Does anyone know if this is working in the latest stable?
Haven't updated yet - and don't want to loose this.
I didn't see it mentioned in the release notes.
Thanks.
Thanks.
running domoticz 3.4834 on rpi2, with
Hue bridge / bulbs.
lightwave rf sockets, mood controlers, sensors & contacts.
Home bridge / Siri.
Ha bridge / echo Alexa.
Hard wired alarm system - setting home / away status.
Next: harmony hub.
Hue bridge / bulbs.
Home bridge / Siri.
Next: harmony hub.
