Cheap 433 relay with switch support
I'm new here, so hello to all!
I'm renovating my home and I would like to put smart relays for the lights. Searching the supported devices list, I see that the price for them is very high (e.g. more than 60€ for a Fibaro FGS221).
On the other hand, aliexpress if full of cheap 433MHz remote relays, but they don't support the addition of a physical pushbutton.
Do you know if a cheap solution with relay AND pushbutton support exists?
- Domoticz version: 4.11333
Re: Cheap 433 relay with switch support
Sonoff and/or sonoff RF i You really need 433
I flashed RF version with espeasy yesterday and it's working great with Domoticz.
____
may
____
may
_______________
- Dell FX-160 / Ubuntu 16.04
- RFLink 433Mhz / NRF 2.4GHz
- 2x Xiaomi Gateway
- different species of ESP8266
- 2x Xiaomi Gateway
Hi!
433 is not mandatory, for me any wireless protocol is OK. I checked the sonoff but I don't see that it has a connector for a switch/pushbutton, I'm seeking for a module supporting both a switch and wireless communication.
- Westcott
The Sonoff has the sort of button you want.
As Mayyam says, with ESPeasy you can program the device to toggle on a button press and update Domoticz, or switch on/off from Domoticz,
It is really neat bi-directional control.
Sorry, I didn't notice that the pairing button can also be used for switching the relay on and off!
I will certainly look into this Sonoff relay, thank you! Do you know other similar devices with a screw connector for the external switch? It's a little bit annoying to disassemble each Sonoff to solder my switch.
BTW, if I have understood correctly, the procedure for the Sonoff is this:
1. Solder a pin strip to the serial pads of the Sonoff and solder my external switch instead of the existing one
2. Flash espeasy via a usb-serial ttl cable
3. Pair it with the 433mhz module on the Rasperry Pi running Domoticz
I'm still a newbie, so my questions are very prosaic!
Thanks again!
Thanks again!
- Westcott
I use my Sonoffs in Wifi mode, it seems more robust than 433MHz, and it's what ESPeasy is really good for!
What does your external switch do that the Sonoff's can't?
I just pushed a 4-pin header into the holes without soldering them.
Contact was good enough for flashing.
Nice info, thanks!Westcott wrote:I use my Sonoffs in Wifi mode, it seems more robust than 433MHz, and it's what ESPeasy is really good for!
I just want the possibility to use a wall switch to control the house lights, I don't want to rely only on the wifi+raspberry combination. Plus It would be uncomfrotable to use only the phone to switch on and off the lights. And finally, if the Sonoff goes south and I have to wait the delivery of another one, or if I move and want to bring with me all the tech stuff, I could replace it with a normal relay and simply control the lights with the wall switches.Westcott wrote:What does your external switch do that the Sonoff's can't?
Re: RE: Re: Cheap 433 relay with switch support
1 - sonoff 10A have a spare 1 pin (14 gpio on the fifth pin) for user where You can connect Your switch instead of ruin existing oneschifazl wrote:Sorry, I didn't notice that the pairing button can also be used for switching the relay on and off!
Thanks again!
____
may
_______________
- 2x Xiaomi Gateway
- 2x Xiaomi Gateway
This is great! I'm really a newbie, so maybe this is a dumb question: the spare pin already has a pull-up/down resistor or I have to add it?
Also: do I have to write the code to debounce and manage the button press by myself, or the ESP Easy already has everything built in?
I think that these are my last questions, at least for now
ESPEasy have it. I don't know about the resistor, but there was no aditional resistor needed in few tutorials i have seen.
____
may
____
may
_______________
- 2x Xiaomi Gateway
- 2x Xiaomi Gateway
Many many thanks, you were very helpful! I've just checked some tutorials about the software part, I'll dig in some more about the hardware connections
- Domoticz version: current
Could these be useful? They have a small button on the front.
https://www.aliexpress.com/item/3-Pack- ... 66759.html
Did you try this product?
I am also looking for a 433mhz relay with a physical button which I can remotely control and also see if it is on/off. The sonoff solution looks a bit complicated.
- Domoticz version: Beta Ch
There are lots of physical wall switches that have 433mhz on them, but unfortunately, i havent found any that will update their state in domoticz if you use physical switch :/ I anyone know, please tell
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
Am looking into a similar thing to work with my rfxtrx433e.
Option 1: LightwaveRf 1 gang dimmer: £35 cheapest for single gang
Pros:
Cons:
Pros:
Cons:
Option 3: Lighting4 relay from ebay: £3 incl shipping from China e.g. http://www.ebay.co.uk/itm/315MHz-433MHz ... i-TMe77Z6w
Pros:
Cons:
Option 4: Sonoff relay
Pros:
Cons:
Also, note that in addition to Lightwaverf there is the Byron Homeeasy EU dimmers as well, and these are somewhat more cheaper. Haven't tried them but they are meant to be compatible with rfxtrx as well..
Pros:
- quality switch
simple to install
compatible with dimmable LEDs
tested and seems to work with CFL for on/off
can be directly paired with £25 PIR sensor
Cons:
- price
receive only
Pros:
- branded quality
works with any existing wall switch and any existing lighting
Cons:
- bit pricey for a relay (esp when multiplied for whole house)
canNOT be directly paired with £25 PIR sensor
receive only
Pros:
- cheap!
works with any wall switch and any existing lighting
Cons:
- quality?
has anyone tested any of these and are happy or not?
Pros:
- branded
cheapish
works with any existing wall switch and any existing lighting?
two way?!
Cons:
- complicated to install with soldering etc.
setup: Domoticz@SynNAS; RFXTRX 433; Response E. Alarm, Teqin IP PTZ Camera, Mercury Socket, 1byOne Chime; SSE smart meter
plan: Lightwave RF Dimmers & PIR, integ. evohome heating
- mrefex
- Domoticz version: 3.7041
Hello Daryah
Can you confirm this relay will work with domoticz ? and which protocol do you use to learn it ?
Pros:
cheap!
I tried these type wall sockets but unfortunately the code did not get through my rflink so it was useless.
https://www.banggood.com/Digoo-RC-13-Sm ... ds=myorder
Now i am going to try these receivers.
https://www.banggood.com/2Pcs-DC12V-10A ... ds=myorder
Pros:
cheap!
I'm kinda new to this, how does it work with any wall switch?Option 3: Lighting4 relay from ebay: £3 incl shipping from China e.g. http://www.ebay.co.uk/itm/315MHz-433MHz ... i-TMe77Z6w
Pros:
cheap!
- Domoticz version: V2024.7
Maybe not ideal but I bought myself some remote controls.
https://www.banggood.com/433Mhz-Transmi ... rehouse=CN
These do learn both th erelays aswell Domoticz.
Now you also can experiment with the 3 different ways to control the relay.
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Chinese sensors temp (Dallas),movement
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
