I am switching on 2 switches via a LUA script. Optimally, I would like to have a delay of ~6 seconds between them.
I could do this via a Scene with an On Delay for the second switch, but I only need the delay if Switch 1 was initially OFF and then switched to ON by th script. (I can check the status of Switch 1 with the script, so I can determine whether I need to switch it.)
I know that it's not advisable to put a delay in a device script, but I don't think the 6 seconds is going to cause any problems with my setup.
Can anyone suggest please a way to do what I want, or should I just go with the Scene and an extra delay each time?
Delay between switches
- emme
- Domoticz version: latest
Re: Delay between switches
does this could help?
EVENT DEVICE
in this way you can switch switch1 manually and the other light will delay 6 secs...
if you want to do it IN the script, it would be not necessary a device event... it could be whatever you want
EVENT DEVICE
local switch1 = 'Put here the name of your first switch'
local switch2 = 'Put here the name of your second (delayed) switch'
local onDelay = 6 -- set the seconds you want to delay
if devicechanged[switch1] and otherdevices[switch1] == 'On'
commandArray[switch2] = 'On AFTER '..onDelay
if otherdevices[switch1] == 'Off'
commandArray[switch1] = 'On'
"We always done this way"
Thanks for the fast reply. I forgot to mention that Switch 2 is relying on an os.execute call as it's talking directly to an amplifier, but I can get around that by creating a dummy switch as you suggest and call the os.execute when it is triggered.
