WS 3080 weather station
Small question. Can i add this to Domoticz? I use Raspberry PI. This have usb. Weewx working with this. Or only over weather underground personal weather station ?
- gizmocuz
Re: WS 3080 weather station
Does the device support 433Mhz / 866Mhz ? because it communicates wireless with the display station
Did you try with an RFXTRX 433?
No. How to try? I have nrf24l01 modules only
- gizmocuz
Then you obviously can not try right? They are for 2.4ghz
Yes. Nrf for 2,4GHz. I connect it to usb if i find time.
- Domoticz version: 3.9639
Ws 3080 is 433mhz Lacrosse if I am not mistaken
You can push device parameters via JSON from weewx mysql into domoticz database using cron. I do the same with cumulusMX
Working great. I send data to weather underground and from this to Domoticz.
