there are weeks I'm struggling (and my domobuddies either) on this issue!!!
First of all the uuid for battery is 0x2A19 (0x180F is the Battery service, but the percentage is the 2 bit at 2a19
thena... it looks like the nut mini does not reply to standard calls OR... gatttool is not able to...
I tries to use Bluez stack from 5.3 to 5.48 (latest) with no success....
based on almost all forums... it looks it is a kernel issue and the best stack to use was bluez 5.11
...but it does not support the internal bt chip (brc43xx)
I was unable to use external BT dongles due to an enumeration error (could it be broken or a kernel issue?!) so the device is not loaded correctly
As per now... I only able to get connection error 107 (endpoint not connected) 111 (connection refused)
MORE... if you bound the nut to its app... it disappear from the network
and least but not last... usign nRF app you're able to see almost all the characteristics... so it's defenetly a software issue!
