Thanks! It's working great now!mvzut wrote:You must fill in the IP address of the Sonos player you want to add. Easiest way to find this is via the Sonos app, under Settings > About my Sonos System.DomoRies wrote:Nice plugin, but what do you need to fill in at ip-adres in Domoticz? Now it's for default 127.0.0.1
Python plugin: Sonos [old version]
Re: Python plugin: Sonos
The plugin is giving errors like these since the last few beta updates:
Some searching revealed that the onNotification implementation in the Python plugin framework was changed recently:
http://www.domoticz.com/forum/viewtopic.php?t=16151
I now changed these lines in the Sonos plugin.py (lines 194-196)
into
No idea what info from the 7 arguments I should copy to the log, I copied the first 4 for now.
@tester22, maybe you can change this in the GitHub repository?
2017-02-19 22:30:02.957 Error: (Sonos Laura) 'onNotification' failed 'TypeError':'onNotification() takes 1 positional argument but 7 were given'.
def onNotification(Data):
Domoticz.Log("Notification: " + str(Data))
return
def onNotification(name, subject, text, status, priority, sound, image_file):
Domoticz.Log("Notification: " + str(name) + ", subject: " + str(subject) + ", text: " + str(text) + ", status: " + str(status))
return
Donemvzut wrote:The plugin is giving errors like these since the last few beta updates:
Some searching revealed that the onNotification implementation in the Python plugin framework was changed recently:Code: Select all
I now changed these lines in the Sonos plugin.py (lines 194-196)intoCode: Select all
def onNotification(Data): Domoticz.Log("Notification: " + str(Data)) return
No idea what info from the 7 arguments I should copy to the log, I copied the first 4 for now.Code: Select all
def onNotification(name, subject, text, status, priority, sound, image_file): Domoticz.Log("Notification: " + str(name) + ", subject: " + str(subject) + ", text: " + str(text) + ", status: " + str(status)) return
@Tester22, maybe you can change this in the GitHub repository?
Anyone else having a problem with the Volume Switch of the Sonos Plugin with the latest Beta and Plugin? Or is there something wrong with my configuration
It doesnt updates the Sonos volume indeedl00pz wrote:Anyone else having a problem with the Volume Switch of the Sonos Plugin with the latest Beta and Plugin? Or is there something wrong with my configuration
Also I miss the timer functionality to switch off my Play 1 automatically. Is that not possible with switch type media player?
Strange. Volume is working on my play5 players and on my Sonos connect. Could you enable debug and add the log output to this thread.Pino112 wrote:It doesnt updates the Sonos volume indeedl00pz wrote:Anyone else having a problem with the Volume Switch of the Sonos Plugin with the latest Beta and Plugin? Or is there something wrong with my configuration
Not sure what automatic shutdown means. As soon as the plugin detects that the player is stopped it will change status to off.
I updated to the latest beta version and it works now. Thanks.tester22 wrote:Strange. Volume is working on my play5 players and on my Sonos connect. Could you enable debug and add the log output to this thread.Pino112 wrote:It doesnt updates the Sonos volume indeedl00pz wrote:Anyone else having a problem with the Volume Switch of the Sonos Plugin with the latest Beta and Plugin? Or is there something wrong with my configuration
- Domoticz version: V3.6838
Not be able to add Sonos Player in Hardware
When selecting the Sonos pluging from the Pulldown box and pressing "Add" it's not updated in the hardware overview.
What can be wrong?
***** 2017-03-03 Problem caused by browser Chrome (Versie 56.0.2924.87)
When trying to add the pluging with my Android tablet all worked well.
Difference is that in Chrome the fields for filling in the IP adres etc. were not visible
In Edge there's also no problem to add the plugin in the hardware
Domoticz V3.6838 (c)2012-2017 GizMoCuz Build Hash: 895a33a
Startup Path: /home/pi/domoticz/
PluginSystem: Started, Python version '3.4.2'.
Jan
What can be wrong?
Jan
Last edited by HomeAutomation on Saturday 04 March 2017 9:17, edited 1 time in total.
Did you fill in the IP address of your Sonos?HomeAutomation wrote:Not be able to add Sonos Player in Hardware
What can be wrong?
Jan
mvzut wrote:Did you fill in the IP address of your Sonos?HomeAutomation wrote:Not be able to add Sonos Player in Hardware
What can be wrong?
Jan
No, I did not, because these fields were not visible .
I normaly work with Chrome. When I tried it on my Android tablet and later in Edge these fields were visble and it all worked well.
Jan
How to control Sonos by LUA script
Does anybody have a example how to control the Sonos plugin with a LUA script?
Jan
Jan
It's just as if you are controlling a lamp: You can use LUA on/off commands (commandArray['<status device name>'] = 'On') to start/pause a player with the current playlist, and you can use the volume device as if it was a dimmer (using e.g. commandArray['<volume device name>']= 'Set Level 30').HomeAutomation wrote:How to control Sonos by LUA script
Jan
As far as I know the plugin can't be used to e.g. skip to the next song or to start a particular playlist. The virtual remote doesn't work (yet).
Is it really that simple?mvzut wrote:It's just as if you are controlling a lamp: You can use LUA on/off commands (commandArray['<status device name>'] = 'On') to start/pause a player with the current playlist, and you can use the volume device as if it was a dimmer (using e.g. commandArray['<volume device name>']= 'Set Level 30').HomeAutomation wrote:How to control Sonos by LUA script
Jan
Thanks, I'll give it a try.
Jan
Does anyone want features like skip track? My idea have been to use this for automation for example switch on the amplifier when Sonos connect is starting. I have used the Sonos app for everything else.mvzut wrote:As far as I know the plugin can't be used to e.g. skip to the next song or to start a particular playlist. The virtual remote doesn't work (yet).HomeAutomation wrote:Jan
The only remaining feature I am planning is TTS as soon as the plugin have support for providing an url that Sonos players can conect to so they can download data.
Skipping tracks etc. is not needed for my purposes. I also primarily use the plugin to activate a Harmony scene (switching on my amp) when my Sonos Connect starts playing. What could be interesting is the ability to start a specific playlist or favourite or radio station. That would enable me to couple e.g. a radio station to a button on my wall mounted tablet running Imperihome, without the need to start the Sonos app.tester22 wrote:Does anyone want features like skip track? My idea have been to use this for automation for example switch on the amplifier when Sonos connect is starting. I have used the Sonos app for everything else.mvzut wrote:As far as I know the plugin can't be used to e.g. skip to the next song or to start a particular playlist. The virtual remote doesn't work (yet).HomeAutomation wrote:Jan
How should that be implemented on in the ui?mvzut wrote:Skipping tracks etc. is not needed for my purposes. I also primarily use the plugin to activate a Harmony scene (switching on my amp) when my Sonos Connect starts playing. What could be interesting is the ability to start a specific playlist or favourite or radio station. That would enable me to couple e.g. a radio station to a button on my wall mounted tablet running Imperihome, without the need to start the Sonos app.tester22 wrote:Does anyone want features like skip track? My idea have been to use this for automation for example switch on the amplifier when Sonos connect is starting. I have used the Sonos app for everything else.mvzut wrote: As far as I know the plugin can't be used to e.g. skip to the next song or to start a particular playlist. The virtual remote doesn't work (yet).
A combo button that the user can add Sonos uri (separated by comma) to under preferences or an notification type that can be triggered by scripts?
TTS would be great!
I agree.RayAmsterdam wrote:TTS would be great!
Just bought my first Sonos Play 1 and allready experience a lot of opportunities for my HomeAutomation
Jan
Yes, but the options I have seen so far requires the script to download the file and than expose it over http so Sonos can download it and that is not currently possible.HomeAutomation wrote:I agree.RayAmsterdam wrote:TTS would be great!
Jan
Also my plan was to use tha asynchronous built in communication layer (haven't been able to get it working thou) and then it is harder to actually know when the player is done playing the message.
Works perfect.mvzut wrote:It's just as if you are controlling a lamp: You can use LUA on/off commands (commandArray['<status device name>'] = 'On') to start/pause a player with the current playlist, and you can use the volume device as if it was a dimmer (using e.g. commandArray['<volume device name>']= 'Set Level 30').HomeAutomation wrote:How to control Sonos by LUA script
Jan
Integreated Sonos in my WakeUp alarm.
Now, based on one time setting, I'm able to control my bedroom light (WakeUp), central heating and Sonos.
Still looking for a Alarm clock pluging however. ?
Last edited by HomeAutomation on Sunday 05 March 2017 13:56, edited 1 time in total.
Users browsing this forum: madpatrick and 1 guest
