Razberry Open Z-wave backup&restore
quazar
Post by quazar »
Because of issues with my raspi setup, I decided to reinstall the system. Where are the Razberry/open z-wave settings stored? Copying the old domoticz folder over the new one does not restore the z-wave setup. It's also not backed up as part of the Domoticz backup... Is this stored somewhere else on the Pi?
i000
Re: Razberry Open Z-wave backup&restore
Post by i000 »
I am interested in how I need to setup my razberry with open z-wave too.
quazar
Post by quazar »
Sorry for my question! The Razberry was not properly configured (e.g. not linked to /dev/ttyAMA0 yet in the Hardware settings menu), after that my Open-Z-wave network was up again!
So, i000: the Razberry should be detected once you've selected the right port (/dev/ttyAMA0 in my case). I do not know how to transfer a network from Z-wave.me to OpenZ-Wave... I chose to reconfigure everything because it was all very buggy under Z-wave.me (1 year ago or so).
i000
Post by i000 »
quazar wrote:Sorry for my question! The Razberry was not properly configured (e.g. not linked to /dev/ttyAMA0 yet in the Hardware settings menu), after that my Open-Z-wave network was up again!
Hi Quazar, is necessary install the open z-wave libraries? Or other soft? I can't make it work.
franzjs
Re: Razberry Open Z-wave installation /Razberry
Post by franzjs »
I'm trying to get the Razberry GPIO-modul running on my PI3 but even with the instruction I've found it's still not working.
Does anybody know how to configure or has anybody a working instruction.
i000
Post by i000 »
I have achieved it, doing the next steps, with a clean installation. These steps are taken from the wiki section in Domoticz page.:
Write image Raspian Jessie Lite on sd-card.
1. sudo raspi-config
1.1 expand Filesystem
1.2 Change User Password
1.3 Change Timezone: set to appropriate timezone
1.4 Advanced Options: Option A3. Memory Split: Set to 16M since we don't need a graphical environment
1.5 Advanced Options: Option A0. Update
1.6 sudo reboot
2. sudo apt-get update
3. sudo apt-get upgrade
4. sudo reboot
5. sudo apt-get install rpi-update
6. sudo rpi-update
7. sudo nano /boot/config.txt
add to end of the file:
dtoverlay=pi3-disable-bt
8. removing 'console=serial0,115200' from cmdline.txt
sudo nano /boot/cmdline.txt
9. sudo systemctl disable hciuart
10. sudo stty -F /dev/ttyAMA0 9600
11. sudo reboot
12. sudo curl -L install.domoticz.com | bash
quazar
Post by quazar »
Strange! I've reset the Zwave.me on my RasPi and try to add my Z-wave devices again.
Most of them can be included, but the following devices are not found:
Everspring AD142 Plug-in Dimmer Module
Everspring AN1582 Wallplug with energy consumption
Should I install the open z-wave libraries? On my previous system I worked with the Zwave.me system under Domoticz before switching to open-Zwave...
i000
Post by i000 »
Now I can't use Domoticz and zwave.me at the same time, like before with low version of Domoticz. I can only use one of these.
I do the steps explained on the before post and Domoticz working fine.
