HUE Power Usage & Energy Script
trixwood
Post by trixwood »
Power HUE
TRiXWooD Scripts viewtopic.php?f=23&t=12145&p=87422#p87422
This is my script for adding virtual Usage and Energy sensors for philips hue lamps and fixing the simple update script ...
This is an approximation in no way are these the real values, there are no sensors on the HUE bulbs and strips. What this script does is using a lookup table which contains readings of the power usage corresponding to the brightness of the HUE light.
Update: with hue remote dimmer switch support see: http://domoticz.com/forum/viewtopic.php ... 418#p85418
Screen Shot 2016-05-01 at 09.42.09.jpg (237.27 KiB) Viewed 14188 times
I used the simple update script for hue as basis... work in progress... Currently thinks all lamps are white bulbs since i did not tried a colored one... but can easily be adjusted buy detecting the right bulb (from the hue json).. Also the reading are done with my powernode 1 probably not that accurate... but this is all approximations anyway... I just wanted to know how much energy the lamp will cost me ;-)
* Improvement of Simple HUE Script (detect unreachable & fix bug)
* Individual & Total Power/Energy virtual readings
It incorperate the SimpleHueScript for updating at the moment.. which is broken btw... that why you have to also change the number of the highestnumberlamp with the highest number you can find in you hue app... (the script is broken because you can delete bulbs which makes a hole in the index of the lamps which the original scripts detects as "we're done"... https://www.domoticz.com/wiki/Simple_sc ... Hue_status
Usage
  • :? Change the number hueMaxIndex which is the highest number in lamps section in the hue app
    :D Change the hueWait which is number of seconds the script is executed, to keep the hue and domoticz responsive
    • ;) recommend 5 seconds
      :cry: you can use 0 but even with the original simple script, the lag between the z-wave door sensor and my hue light is in the range of 0.5 seconds to 20s slower, not recommended.
    :P Change the hueRefresh which is number of seconds before the meters are updated anyway regardless is they where changed or not
    • :geek: recommend 60 seconds
    :?: Enter your IP and API key of the HUE bridge
    :!: If your HUE Lamp is called "Bureau Lamp" you will need to add new virtual sensors "Bureau Lamp Power" & "Bureau Lamp Power Meter". Do this for all your lights
    Screen Shot 2016-05-01 at 09.31.37.jpg (35.12 KiB) Viewed 14192 times
    Screen Shot 2016-05-01 at 09.31.28.jpg (32.86 KiB) Viewed 14192 times
    :idea: Add virtual sensors "HUE Power" and "HUE Power Meter" which are the accumulation of all the HUE lamps individual components (I mean total summation of all the... you get it the TOTAL)
    :roll: MAKE SURE YOU RESTART DOMOTICZ the new virtual sensors will not work in my version 3.5xxx until I restart... :-/
    :o Add this script in the event section, as a device event.
    :shock: Remove comment before the print statements for debug
    That's it... :ugeek:
Note In some versions commandArray[hue_name] = 'Off' works (v3.5076) but commandArray[otherdevices_idx[hue_name]] = { ['UpdateDevice'] = otherdevices_idx[hue_name]..'|0|'.. 'Off' } does nothing, while in (v3.49) the first one sometimes works while the second one works perfectly... not sure if this is broken? The problem is only with the On/Off virtual sensor switch...btw ♫♬ squash that bug ♪♩♬
v0.1 Tryout
v0.2 Typos & Bug fixed
v0.3 Time Bug Fixed
v0.4 Detect Lamp Types (HUE 800 lum & White added)
-- TRiXWood May 2016
-- https://www.domoticz.com/forum/viewtopic.php?f=23&t=11778&p=84624#p84624
-- configure Hue Bridge
local hueBridgeIP = '10.0.0.90'
local hueBridgeAPI = '73a9ade4584754567397aa767b88'
-- Max index of lights in the Philips App
-- this is not the number of lights you have!!!
-- since numbering continues if you delete a lamp, so check app!
local hueMaxIndex = 23
-- Wait time (sec) until script executes
local hueWait = 5
-- Wait time (sec)  until refresh without change (so it stays blue not red)
local hueRefresh = 60
-- Names of the total power & powermeter sensors
local huePower = "HUE Power"
local huePowerMeter = "HUE Power Meter"
-- do not change beyond this line
-- this part will get the Hue status
function getHueLight(id)
   local http = require('socket.http')
   local ltn12 = require('ltn12')
   local json = require('dkjson')
   stop = false
   t = {}
   local url = string.format("http://%s/api/%s/lights/%s", hueBridgeIP, hueBridgeAPI, id)
   b, c, h = http.request{url=url, sink = ltn12.sink.table(t), method='GET'}
   huestring = tostring(table.concat(t))
   local hue, pos, err = json.decode(huestring, 1, nil)
   --print (huestring)
   if (hue.name) then
      hue_name = (hue.name)
      hue_state = (hue.state.on)
      hue_level = (hue.state.bri)
      hue_reachable = (hue.state.reachable)
      hue_model = (hue.modelid)
      if not hue.state.reachable then hue_state = false end
     hue_name = "ERROR"
     stop = true
   return hue_name, hue_state, stop
function timedifference(s)
   year = string.sub(s, 1, 4)
   month = string.sub(s, 6, 7)
   day = string.sub(s, 9, 10)
   hour = string.sub(s, 12, 13)
   t1 = os.time()
   difference = os.difftime (t1, t2)
   return difference
-- now check Hue state & correct Domoticz if needed
if timedifference(otherdevices_lastupdate[huePower]) > hueWait then
i = 1
powertotal = 0
repeat
   local hue = getHueLight(i)
   -- Powercode!!!
   -- new powercode create for every lamp a virtual usage (energy) sensor called the name of the lamp with "Power"
   -- Example: "Bureau Lamp" you will need to add virtual usage (energy) sensor called "Bureau Lamp Power"
   hue_power_name = hue_name .. " Power"
   hue_powermeter_name = hue_power_name .. " Meter"
   -- I thought level would be 0..99 but domoticz its 0..15 und hue its 0..254 or something
   -- Anyway defaulting to 0..99
   level = 0
   if hue_state then
       level = hue_level / 2.56
   -- Philips Light Measuring with Powernode 1 (inaccurate :-)
   modelfound = false
   -- Model LCT007 (800 lum v2 HUE bulb)
   if hue_model == "LCT007" then
       modelfound = true
   if level <= 0 then watt = 0.4 end
   if (level > 0 and level <= 6) then watt = 1.6 end
   if (level > 6 and level <= 13) then watt = 1.7 end
   if (level > 13 and level <= 20) then watt = 1.8 end
   if (level > 20 and level <= 26) then watt = 1.9 end
   if (level > 26 and level <= 33) then watt = 2.2 end
   if (level > 33 and level <= 40) then watt = 2.4 end
   if (level > 40 and level <= 46) then watt = 2.7 end
   if (level > 46 and level <= 53) then watt = 3.0 end
   if (level > 53 and level <= 60) then watt = 3.5 end
   if (level > 60 and level <= 66) then watt = 3.9 end
   if (level > 66 and level <= 73) then watt = 4.5 end
   if (level > 73 and level <= 80) then watt = 5.1 end
   if (level > 73 and level <= 86) then watt = 5.5 end
   if (level > 86 and level <= 93) then watt = 6.4 end
   if (level > 93) then watt = 6.7 end
   -- Model LWB006 (White Bulb)
   if hue_model == "LWB006" then
           modelfound = true
   if level <= 0 then watt = 0.3 end
   if (level > 0 and level <= 6) then watt = 1.4 end
   if (level > 6 and level <= 13) then watt = 1.5 end
   if (level > 13 and level <= 20) then watt = 1.7 end
   if (level > 20 and level <= 26) then watt = 1.8 end
   if (level > 26 and level <= 33) then watt = 2.0 end
   if (level > 33 and level <= 40) then watt = 2.2 end
   if (level > 40 and level <= 46) then watt = 2.5 end
   if (level > 46 and level <= 53) then watt = 2.9 end
   if (level > 60 and level <= 66) then watt = 3.8 end
   if (level > 66 and level <= 73) then watt = 4.6 end
   -- fucked up here nog een keer meten 5.2W ???
   if (level > 73 and level <= 80) then watt = 5.5 end
   if (level > 80 and level <= 86) then watt = 6.5 end
   if (level > 86 and level <= 93) then watt = 7.7 end
   if (level > 93) then watt = 9.0 end
   -- Model LST001 Lightstrip
   if not stop and not modelfound then
      print("HUE Power: Unsupported Lamp Detected Model "..hue_model)
      print("Please add & submit to https://www.domoticz.com/forum/viewtopic.php?f=23&t=11778&p=84624#p84624")
      watt = 0
   if not hue_reachable then watt = 0 end
   if not stop then powertotal = powertotal + watt end
   if not stop and (otherdevices_svalues[hue_power_name] ~= tostring(watt) or timedifference(otherdevices_lastupdate[hue_power_name]) > hueRefresh) then
      -- print ("HUE Power (" .. hue_power_name .. ") Power: " .. otherdevices_svalues[hue_power_name] .. " Watt -> " .. watt .. " Watt")
      commandArray[otherdevices_idx[hue_power_name]] = { ['UpdateDevice'] = otherdevices_idx[hue_power_name]..'|0|'.. watt }
      powerold, energyold = string.match(otherdevices_svalues[hue_powermeter_name], "(%d+%.*%d*);(%d+%.*%d*)")
      interval = (timedifference(otherdevices_lastupdate[hue_powermeter_name]) / 3600)
      commandArray[otherdevices_idx[hue_powermeter_name]] = { ['UpdateDevice'] = otherdevices_idx[hue_powermeter_name] .."|0|" .. watt .. ";" .. (powerold*interval+energyold) }
      -- print ("HUE Power (" .. hue_powermeter_name .. ") Power: " .. powerold .. " Watt -> " .. watt .. " Watt - Usage: " .. energyold .. " kWh -> " .. powerold*interval+energyold .. " kWh")
  if not stop and hue_state == true and otherdevices[hue_name] == 'Off' then
     -- DOES NOT WORK sometimes it updates sometimes it doesnot...
           commandArray[hue_name] = 'On'
     -- USE
      --commandArray[otherdevices_idx[hue_name]] = { ['UpdateDevice'] = otherdevices_idx[hue_name]..'|0|'.. 'On' }
      --print ("HUE Correction (" .. hue_name .. ") State: Off -> On")
   elseif  not stop and hue_state == false and otherdevices[hue_name] ~= 'Off' then
  --    commandArray[otherdevices_idx[hue_name]] = { ['UpdateDevice'] = otherdevices_idx[hue_name]..'|0|'.. 'Off' }
      --print ("HUE Correction (" .. hue_name .. ") State: On -> Off")
   i = i + 1
    -- more hue lamps then change this...
until(i > hueMaxIndex)
if (otherdevices_svalues[huePower] ~= tostring(powertotal)) or timedifference(otherdevices_lastupdate[huePower]) > hueRefresh then
   commandArray[otherdevices_idx[huePower]] = { ['UpdateDevice'] = otherdevices_idx[huePower]..'|0|'.. powertotal }
   powertotalold, energytotalold = string.match(otherdevices_svalues[huePowerMeter], "(%d+%.*%d*);(%d+%.*%d*)")
   interval = (timedifference(otherdevices_lastupdate[huePowerMeter]) / 3600)
   commandArray[otherdevices_idx[huePowerMeter]] = { ['UpdateDevice'] = otherdevices_idx[huePowerMeter] .."|0|" .. powertotal.. ";" .. (powertotalold*interval+energytotalold) }
   --print ("HUE Power (" .. huePower .. ") Power: " .. otherdevices_svalues[huePower] .. " Watt -> " .. powertotal .. " Watt")
   --print ("HUE Power (" .. huePowerMeter .. ") Power: " .. powertotalold .. " Watt -> " .. powertotal .. " Watt - Usage: " .. energytotalold .. " kWh -> " .. powertotalold*interval+energytotalold .. " kWh")
trixwood
Re: HUE Power Usage & Energy Script
Post by trixwood »
Ha!
Now its completely working on the domonicz side, with no lag time anymore in domoticz. I would like some better readings of the powerusage of the HUE lamps. Because this is an approximation in no way are these the real values, there are no sensors on the HUE bulbs and strips. What this script does is using a lookup table (well if statement at the moment) which contains readings of the power usage corresponding to the brightness of the HUE light.
Anybody?
I do not have the old bulbs for example...
Kiliansitel
Post by Kiliansitel »
Hi there,
thanks for the script but having some ussues with this, did everything according to your instructions but I keep getting this error:
Error: EventSystem: in test: [string "-- TRiXWood May 2016..."]:266: attempt to concatenate field '?' (a nil value)
corresponding to this line in the script:
Also strange is that only a few lamps (6) are getting the power value the other 12 nothing.
my domoticz version is 3.5187
the issue is the same with your hue dimmer support script http://domoticz.com/forum/viewtopic.php ... 418#p85418
Thanks for your help !
Grtz
trixwood
Post by trixwood »
You probably have unsupported lamps... I cannot guess the wattage of lamps I do not have, you should add them, thats why you get 0 with some lamps :-)
Currently supported are
And you are welcome to add additional or better reading of the current lamps to this script by posting them here.
About the nil value, i don't have domoticz right here to test, but it is because of the missing lamps (which means there is a bug in the code) or that you mistyped somewhere and did not name them correctly, this weekend I hopefully have time to check, not promising anything.
Martijn85
Domoticz version: Stable
Post by Martijn85 »
I got the same message:
2017-01-30 10:32:00.293 LUA: Please add & submit to viewtopic.php?f=23&t=11778&p=84624#p84624
2017-01-30 10:32:00.306 LUA: HUE Power: Unsupported Lamp Detected Model LCT010
2017-01-30 10:32:00.306 LUA: Please add & submit to viewtopic.php?f=23&t=11778&p=84624#p84624
2017-01-30 10:32:00.320 LUA: HUE Power: Unsupported Lamp Detected Model LCT010
2017-01-30 10:32:00.320 LUA: Please add & submit to viewtopic.php?f=23&t=11778&p=84624#p84624
2017-01-30 10:32:00.333 LUA: HUE Power: Unsupported Lamp Detected Model LWB010
2017-01-30 10:32:00.333 LUA: Please add & submit to viewtopic.php?f=23&t=11778&p=84624#p84624
2017-01-30 10:32:00.333 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_time_hue_power.lua: /home/pi/domoticz/scripts/lua/script_time_hue_power.lua:150: attempt to concatenate field '?' (a nil value)
Will there be support for other lamps?
Gravityz
Domoticz version: 2026.3
Post by Gravityz »
like this thread but can not get it to work since i do not have a valid luasocket for my synolgy 112+ (marcell cpu)
anybody knows where to get this
woodtrix
Post by woodtrix »
@Martijn85, all the measurements are done roughly, with a z-wave powernode 1... (just to remind you this is not an official/accurate measurement and the script gives an approximation of the actual power used, based on my measuring results...) I have quite a few new type of philips lamps but never bothered to measure them. You could measure yourself and add the missing lamps :-) You will get in trouble with the rgb strips extension cords... (how can you detect that... ;-) Or copy and paste the missing lamps from already measured ones... it will be off a little bit because lamps power consumption vary a little bit, but still give a little indication... but might I suggest appending the script with new measurements ;-)
Martijn85
Post by Martijn85 »
Ok thanks for the reply. Will look in to it, if in have some updates i will post them.
thijsvb
Post by thijsvb »
Thanks for the script. I'm trying to implement this at the moment.
I'm missing some lamps in het script.
The Innr GU10 light: RS 125
The hue iris color: LLC010
And the hue ambiance candle: LTW012
Would be great if these lamps could be added as well!
ben53252642
Post by ben53252642 »
Trixwood, slightly un-related question... are you hearing a high pitch buzzing noise coming from your Lightstrips?
I've just added one to my wardrobe and the noise is driving me crazy.
assenzuid
Post by assenzuid »
thijsvb wrote: Saturday 13 January 2018 12:20 Hi,
Also for the LWB010 and LCT012
PaulM
Post by PaulM »
I get the following error:
2018-05-31 15:57:16.803 Error: EventSystem: in hue_status_update_2.lua: [string "-- TRiXWood May 2016 ..."]:52: bad argument #1 to 'sub' (string expected, got nil)
Line 52:
Any clue how to solve this?
phermn
Domoticz version: 4.9971
Post by phermn »
Hi PaulM, I'm having the exact same problem! Did you ever manage to resolve this issue by any chance?
jeroenvanpelt
Domoticz version: 3.8153
Post by jeroenvanpelt »
phermn wrote: Sunday 23 September 2018 5:00 Hi PaulM, I'm having the exact same problem! Did you ever manage to resolve this issue by any chance?
Most likely you have not created a Power and a Power Meter virtual sensor for every Hue light that is in your Domoticz. The error is triggered when the code tries to add up power values for Hue lights assuming you have created "<Light name> Power" and "<Light name> Power Meter" virtual sensors for every single one.
Domoticz latest stable - RaspberryPi 2 B - MySensors - Controlicz - Google Home - RFLink (w/MiLight)
