A lot of push notifications
richardvd
Post by richardvd »
The script below send me an push notification when my garage is open for more then 4 minuten.
unfortunately i get a lot of push notifications (about 30-60 in one minute).
How can i change the script so that i only get one push notification?
sensors = {'Garagedeur'}
-- All times in minutes
firstWarningTimeMinutes = 4
-- Then repeat every .. minutes
repeatTimeMinutes = 5
-- First %s is the sensor name, the second one the time in minutes
firstWarningMessage = 'Info#Let op, "%s" staat al meer dan %s minuten open!'
repeatWarningMessage = 'Waarschuwing#LET OP, "%s" nog steeds open! Tijd open: %s minuten!!'
-- Don't edit below this line
firstWarningTime = firstWarningTimeMinutes * 60
repeatTime = repeatTimeMinutes * 60
timeNow = os.time()
for index,sensor in pairs(sensors) do
    s = otherdevices_lastupdate[sensor]
    -- returns a date time like 2013-07-11 17:23:12
    year = string.sub(s, 1, 4)
    month = string.sub(s, 6, 7)
    day = string.sub(s, 9, 10)
    hour = string.sub(s, 12, 13)
    timeLastOpened = os.time{year=year, month=month, day=day, hour=hour, min=minutes, sec=seconds}
    difference = (os.difftime (timeNow, timeLastOpened))
    if (otherdevices[sensor] ~= 'Open' or difference < firstWarningTime) then
        -- Door closed or within margin
    if (difference <= (firstWarningTime + 60)) then
        -- First warning
        commandArray['SendNotification'] = string.format(firstWarningMessage, sensor, tostring(firstWarningTimeMinutes))
        offset = (difference - firstWarningTime) % repeatTime
        if offset > 0 and offset <= 60 then
            commandArray['SendNotification'] = string.format(repeatWarningMessage, sensor, tostring(math.floor(difference / 60)))
Thanx for the reactions.
Greetz Richard,
jvdz
Domoticz version: 4.107
Re: A lot of push notifications
Post by jvdz »
richardvd wrote: How can i change the script so that i only get one push notification?
Not sure I understand as your code shows you have 2 type of notifications, one initial one and one as reminder.
How exactly and how often would you want these to be send?
Jos
richardvd
Post by richardvd »
I want to receive 1 notification after 4 minutes and then a reminder every 5 minutes, until the door is closed.
jvdz
Post by jvdz »
Understood, so you want to make this a Time script. Have you set it to that in the internal editor?
That way it will only run one time per minute on the minute.
Guess it is now set to All which caused it to run with each change of a registered device.
Jos
richardvd
Post by richardvd »
The LUA script is been written in the internal LUA editor of Domoticz.
Do you mean that i have to put the script to a file and than schedule it with a cron every minute?
Or do you mean something else?
I'm a newbie with LUA scripting, so excuse me if i ask stupid questions :-).
richardvd
Post by richardvd »
Now i understand, i have to change the event type from 'All' to 'Time'
I think it is working right now.., thank a lot Jos!
