measure 10..15V DC and send it to Domoticz?
Is is possible to (build a system that) measure(s) the voltage of a 12V lead cell and make the result visible as a device within domoticz?
SweetPants
Re: measure 10..15V DC and send it to Domoticz?
Everything is possible if you are not afraid to build some hardware yourself.
- Domosapiens
- Domoticz version: V3.5981
ESPEasy
http://www.letscontrolit.com/wiki/index ... troduction
Plus INA 219
https://www.google.nl/search?q=ina+219& ... BygA&dpr=1
Plus INA 219
MattLittle
Yep, real easy.
I have one in my tunnelhouse, you need a voltage divider conntected to A0. I dont remember the values I used for the resistors however you need to convert your MAX anticipated voltage (I used 14.8V I think) to 1.1V. A pot would work well.
Here is some cut/pasted code from my sketch to give you an idea, I got this from the mysensors battery sensor page.
It wont run by itself rather just give you an idea
https://www.mysensors.org/build/battery...
This will send battery voltage as a trackable/graphable value by domoticz as well as a value you can read under devices .
send(msgBat.set(Vbat, 2))Code: Select all
sendBatteryLevel(batteryPcnt)Code: Select all
#define VMIN 11 // Vmin (radio Min Volt)=11
#define VMAX 14.5 // Vmax = (2xAA bat)=14.5
int batteryPcnt = 0; // Calc value for battery %
int BATTERY_SENSE_PIN = A0; // select the input pin for the battery sense point
void setup() {
analogReference(INTERNAL);
void presentation()
// Send the sketch version information to the gateway and Controller
sendSketchInfo("BATLEVEL", "1.0");
present(CHILD_ID_BAT, S_MULTIMETER);
void loop()
int sensorValue = analogRead(BATTERY_SENSE_PIN);
float Vbat = sensorValue * 0.0139644;
int batteryPcnt = static_cast<int>(((Vbat-VMIN)/(VMAX-VMIN))*100.);
sendBatteryLevel(batteryPcnt);
send(msgBat.set(Vbat, 2));
/*Serial.print("VBat");
Serial.print(Vbat);
Serial.print("SensorValue");
Serial.print(sensorValue);*/
wait(SLEEP_TIME);
}Who is online
