Snowtiger wrote:Brutus wrote:I don't understand why you would like to have all the values in one sensor like WU does. I think the sensors of WU are a mess, I see the temperature on three sensors at the same time and the "Wind" sensor is linked to a separated temperature sensor. Changing the name for one of the two sensors will change the other one to. Not logical to me.
So for me I hope it gets separated so its clean.
You can separate it yourself - why 8 or ten values added by one hardware device - to much device sensors which you do not use
And after all , its also a matter of taste ...
I agree with you that it's a personal taste and we don't need to have a lot of unnecessary sensors in our device lists
But I think it's logic that you combine the sensors that are related to each other. For example:
* Temperature
* Wind speed - Wind Direction - Wind Chill - Wind Speed Gust.
* Barometer - Barometer Forecast
* etc
For me I think the separation of the linked temperature sensors is a good way to start
With the latest update we have a separated Temperature sensor, Wind sensor with again a linked temperature sensor you can't delete.
1x Intel NUC8i5BEK (Windows 10 x64) Domoticz on Virtualbox with DietPi.
1x Aeon Labs USB Z-Stick S2
1x P1 Smart Meter USB
28x Fibaro Modules
SMA Solar System
Daikin Airco / Heating
Denon DHT-S716H & DSW-1H
