[Plugin now available in Beta] Help with Yeelight Bulb
deennoo
Re: [Plugin now available in Beta] Help with Yeelight Bulb
ok ! white temp for mono is 4000k
http://domo-attitude.fr
deennoo
Adding a how to run scene for Yeelight Mono/White on the wiki :
https://www.domoticz.com/wiki/Yeelight
- LouiS22
I know thatdeennoo wrote:ok ! white temp for mono is 4000k
- LouiS22
I ordered two of them, will compare it visually.Justinb81 wrote:You can set your own Default color/temperature that the RGBW bulb uses on startup. It remembers the settings. The White only is really white, and I only use it in hallwaysLouiS22 wrote:Guys, a quick help needed.
Does anyone know the default color temperature of the RGBW bulb (I mean the one when I first switch it on)? I'd like to compare it with the white only one (which is 4000k). If it's the same, then I could use the white only (cheaper one) bulbs in certain places.
Thanks in advance!
- Westcott
Hi LouiS22,
I've got 2 RGBs that I use as warning, welcome, and night lights.
They flash different colours depending on the warning.
All controlled from Lua.
deennoo
Re: RE: Re: [Plugin now available in Beta] Help with Yeelight Bulb
Your welcome to update the wiki if you got some cool feature scene with your yeelight rgbw,Westcott wrote:Hi LouiS22,
bertbigb
Re: Help with Yeelight Bulb
Derik wrote:dear...
Looks the Yeelight is killing my Domoticz....
When i remove the light in my lan domoticz is crashing....
And it is turning in to a loop of crashes.
Yeelight hardware off, domoticz stable...
I'm still having problems with that. (on Raspberry and Synology) I have my Yeeligght bulbs connected via DHCP. That could mean that they have a different ip every day. I can't bind them over a mac address since my router doesn't support that (max 10 bindings) and I have 12 bulbs and some other stuff what needs a fixed ip. This also means I have new hardware every day when the ip has changed and existing hardware (since the ip is not connected anymore) does no longer exist. This causes every day a system hang up. Is there a possibility to connect to the yeelights with help of the mac address?
Hope you can do something for me. For the rest I like the lights and the interface to Domoticz very much!! Thanks for all the efforts you put in it.
Best regards Bert
Synology DS1517+ - DSM 6.2
deennoo
Juste change your router for a Real one and remove your toy
- corbin
It was originally coded based on the hardware address of the light, but we changed to storing the IP address as it works better with Domoticz that way. It is better to have static IPs so that scripts can address the lights as well. I think your best solution is to get another router as suggested by deennoo.bertbigb wrote:Is there a possibility to connect to the yeelights with help of the mac address?
bertbigb
Thanks for your answer, I will invest in a new onecorbin wrote:It was originally coded based on the hardware address of the light, but we changed to storing the IP address as it works better with Domoticz that way. It is better to have static IPs so that scripts can address the lights as well. I think your best solution is to get another router as suggested by deennoo.bertbigb wrote:Is there a possibility to connect to the yeelights with help of the mac address?
Best regards Bert
hekm77
deennoo, thanks for your job.
1. I added dummy selector switch 'Test' and set it as a dimmer on switch page.
2. I created LUA script from the Wikis example.Can you help me?
- Spoiler: show
2017-02-11 09:34:03.300 Error: EventSystem: in Test: [string "commandArray = {}..."]:6: attempt to index global 'devicechanged' (a nil value)- LouiS22
Have you changed the ip and the port to yours?hekm77 wrote:deennoo, thanks for your job.
2. I created LUA script from the Wikis example.But I have an error in the log.
- Spoiler: show
Can you help me?Code: Select all
hekm77
Yes, of course. In the script my IP and Port.LouiS22 wrote:Have you changed the ip and the port to yours?
I can change the White Teperature, but have an error in the log.
deennoo
yes i can help, you didn't read all the wiki...hekm77 wrote:deennoo, thanks for your job.
- Spoiler: show
Have you change the lua script Type to "device" from "all" ?
hekm77
You're a magician. Thank you.deennoo wrote: Have you change the lua script Type to "device" from "all" ?
Sorry, English is not my language.
deennoo
Mine not too
rtenklooster
I've enabled the yeelight controller. The log files shows:
For some reason the led light is not listed under my devices.
I've added a bulb manually, but that's not listed under devices aswell.
I've removed the controller, added it again.. still the same problem.
Updated to the latest beta, still not listed under devices. Am i missing something?
2017-02-19 17:57:12.198 YeeLight: New Light Found (192.168.10.7/YeeLight LED (Color))I've added a bulb manually, but that's not listed under devices aswell.
- LouiS22
Is it possible to control groups (for ex: 4 bulbs simultaneously) with the script posted on domoticz wiki?
bertbigb
I struggled with the same in the begining. The solution was simple as the wiki stated: You first need to enable developer mode on your bulbs through the Yeelight Android or iOS Apprtenklooster wrote:Hi,
I've enabled the yeelight controller. The log files shows:For some reason the led light is not listed under my devices.Code: Select all
Best regards Bert
bertbigb
I do that with something like:LouiS22 wrote:Is it possible to control groups (for ex: 4 bulbs simultaneously) with the script posted on domoticz wiki?
--YEELIGHT
-- port number for the yeelights
PORT = '55443'
--IP adresses of the bulbs involved,
local IPs = {'192.168.2.80', '192.168.2.81', '192.168.2.82', '192.168.2.83', '192.168.2.84', '192.168.2.85'}
function YeelightOff()
--command Yeelight Off
for n,IP in pairs(IPs) do
runcommandYeelight = "sudo echo -ne '{\"id\":"..n..",\"method\":\"set_power\", \"params\":[\"off\", \"smooth\", 500]}\\r\\n' | /opt/bin/nc -w1 " ..IP.." " ..PORT.."";
os.execute(runcommandYeelight)
function YeelightTemperature(WhiteYee, DimYee, DurationYee)
--Yeelight part
--runcommandYeelight = "sudo echo -ne '{\"id\":1,\"method\":\"set_scene\",\"params\":[\"ct\", " .. WhiteYee .. "," .. DimYee .. "]}\\r\\n' | nc -w1 " ..IP.." " ..PORT.."";
--runcommandYeelight = "sudo echo -ne '{\"id\":1,\"method\":\"set_ct_abx\",\"params\":[" .. WhiteYee .. ",\"smooth\","..DurationYee.."]}\\r\\n' | nc -w1 " ..IP.." " ..PORT.."";
runcommandYeelight ="sudo echo -ne '{\"id\":"..n..",\"method\":\"start_cf\",\"params\":[1,1,\"" ..DurationYee..",2,"..WhiteYee..","..DimYee.."\"]}\\r\\n' | /opt/bin/nc -w1 " ..IP.." " ..PORT.."";
if debug then print(runcommandYeelight) end
YeelightOff() or something like YeelightTemperature(WhiteYeeValue, DimYeeValue, DurationYeeValue)
The function will run for all IP's in the list IPs
Hope this helps you.
If you want i can share the complete scripts if that is more helpful
Best regards Bert
