Domoticz and evohome wifi
roger47
Post by roger47 »
I have an wifi evohome controller setup operating 12 HR80 UK individually zoned radiator valves and the wireless evohome domestic hot water temp sensor and relay operating a zone valve and also an evohome wifi boiler relay on a Gas Rayburn Nouvelle. It appears to be working well. (Although the wiring logic was not correctly shown in the Honeywell installation books) I want to continuously log individual zone temps, including hot water, say every 2 hrs (could be less frequent) and ideally access this log remotely either on a pc, or ipad/iphone.
Questions, 1) Is there any way Domoticz could organise that and if so how? 22) Any idea how much hard disc storage space this would use?
Operating system available is win7 pro.
(I have asked Honeywell and they say that this cannot be done with any of their kit)
Re: Domoticz and evohome wifi
Hi Roger, if your temperature data is also send to Honeywell than it should be possible.
I have it working on Linux(on my Synology NAS)
Standard implementation in Domoticz is via Python scripts but because I can hardly read Python, I created a bash script to get the values from https://tccna.honeywell.com/WebAPI with curl and put them in Domoticz with json and in a mySQL database.
dlefol
Post by dlefol »
If I understand well what you want, the instruction on the wiki page for Evohome should enable you to do that and more:
https://www.domoticz.com/wiki/Evohome
StanHD
Post by StanHD »
Something like this?
Python:- Broadlink RM2, Sonos
dlefol
Post by dlefol »
Hi StanHD,
Sorry this is a bit out of topic but which software did you use to design your floorplan ? I wanted to do one like that for my own setup, but could not find any nice icons. I like yours very much :)
StanHD
Post by StanHD »
dlefol wrote:Hi StanHD,
Just Windows Paint or Paint.Net, nothing special. The Symbols I just drew myself using the same paint program. :) ;)
Lebo2d9
Domoticz version: L stab
Post by Lebo2d9 »
Does someone have trouble with the evo-update?
Since this morning i get these errrors
INFO:urllib3.connectionpool:Starting new HTTPS connection (1): tccna.honeywell.com
  File "./evo-update.sh", line 32, in <module>
    fi=client.full_installation()
  File "/usr/local/lib/python2.7/dist-packages/evohomeclient2/__init__.py", line 99, in full_installation
    return self._convert(r.text)
  File "/usr/local/lib/python2.7/dist-packages/evohomeclient2/base.py", line 32, in _convert
    return json.loads(object)
  File "/usr/lib/python2.7/json/__init__.py", line 338, in loads
    return _default_decoder.decode(s)
  File "/usr/lib/python2.7/json/decoder.py", line 366, in decode
    obj, end = self.raw_decode(s, idx=_w(s, 0).end())
  File "/usr/lib/python2.7/json/decoder.py", line 384, in raw_decode
    raise ValueError("No JSON object could be decoded")
ValueError: No JSON object could be decoded
Kind regards
Domoicz on RPI3 (wifi) directly connected 3x ds18b20 for CV temp, Evohome (9 zone), 1 remote 220V switch based on ESP-12. RFXtrx433E, 16x AMST-606, 5 Somfy RTS motors
Domoticz on RPI3(wifi) as slave for terraruim control
More to come
