Accessing domoticz behind 3G
mich007
Post by mich007 »
I have domoticz running on raspberry pi 2, and connected to the 3g network via a Huawei (3g to wifi).
I am able to connect to domoticz on the Lan.
How can I connect to domoticz from the internet ?
Some info :
- ISP is free telecom (French company)
- dynamic PUBLIC IP behind NAT
I have seen some forums with reverse ssh tunnel, however I don't know how it works or if it works.
Thank you for your help.
markjgabb
Domoticz version: 3.8153
Re: Accessing domoticz behind 3G
Post by markjgabb »
i used to have the same thing when my ip was behind a nat....so that usually means you outward facing ip isnt your actuall ip....it also means you cant use a standard vpn server on your network.....
basically i couldnt resolve this issue for myself
its the double nat that kills you...... if its setup anything like mine
basically you share your public ip with like 20-30 people and the isp only has to use a fraction of the public ip's it usually would, saves them a tonn of money, and only 1 in 100 would ever notice the issue
unless your isp is willing to open a port or two for you to setup a direct vpn, your going to stuggle
V 2020.2 RPI 3
RFlink 334 mhz
mysensors
broadlink
Mirabella Genio Globes
