2 identical 433mhz sensors, how do they cope in rflink ? Topic is solved
tontze
Domoticz version: Beta Ch
Post by tontze »
Can i use two same kind of sensor, if they dont have selector to make them unique ? How do they cope in rflink ?
-T
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
Stuntteam
Re: 2 identical 433mhz sensors, how do they cope in rflink ?
Post by Stuntteam »
If you want a serious answer, you should at least tell what device that would be..
In most cases devices have a more or less unique ID / random device code and some have also a switch to select a channel number.
There is a hand full of devices (thus not that many) that do not have any special 'unique' ID but only have a channel selector.
In that case you can not use more than 3 or 5 devices of the same type.
