I figure I want to combine the best of both worlds (and also the Domoticz machine is not in a good location with regard to radio transmission)
In Domoticz, I tried adding "Razberry Z-Wave via LAN interface (HTTP)" as new hardware device, with the correct IP/ port but all I get in the log is "Error: Razberry: Error getting data!"
If I log in to shell on the machine running Domoticz I can type
wget -O - http://192.168.x.x:8083/ZWaveAPI/Data/0Looking at https://github.com/domoticz/domoticz/bl ... zberry.cpp it seems to be the kind of URL that would be requested:
const std::string CRazberry::GetControllerURL()
std::stringstream sUrl;
if (m_username.empty())
sUrl << "http://" << m_ipaddress << ":" << m_port << "/ZWaveAPI/Data/" << m_updateTime;
sUrl << "http://" << m_username << ":" << m_password << "@" << m_ipaddress << ":" << m_port << "/ZWaveAPI/Data/" << m_updateTime;
return sUrl.str();
}What could be the problem, is Domoticz supposed to be able to incorporate Razberry z-wave devices from a different machine this way or am I misunderstanding something fundamental? I could not find much documentation on this "Razberry Z-Wave via LAN interface (HTTP)" option ....
Is there a better way around this problem that i am not aware of since I'm a total newbie? Putting the Razberry card into the Domoticz machine is something I am trying to avoid (like i said for radio transmission reasons)
Version: 3.4834
Build Hash: 8398125
Compile Date: 2016-03-02 08:43:51
cheers
