times running in half second slices?
edgarhildering
Domoticz version: 2023.2
Post by edgarhildering »
I am using the command 'Off AFTER 1800' to turn off a switch after 30 minutes. The documentations states: 'Off AFTER nnn' nnn in seconds.
However, the switch changes its state after 15 minutes (exactly). My questions:
- anyone with the same experience?
- is it a bug in domoticz or in the documentation?
For now I multiplied all AFTER-values with 2... i.e. half an hour switch time= 3600.
Any respons is appreciated,
--Edgar
Version: 3.5877
Build Hash: 15b013c
Compile Date: 2016-11-10 16:44:33
Uptime: 22 Days, 1 Hours, 28 Minutes, 45 Seconds
RaspberryPi running Domoticz 2025.2
PIRs + lightswitches
thermometers + heating control
hygrometers + dehumifiers
TUYA switches
Domosapiens
Domoticz version: V3.5981
Re: times running in half second slices?
Post by Domosapiens »
Related to this?
When time flies: Off Delay
http://www.domoticz.com/forum/viewtopic.php?f=6&t=14427
SweetPants
Post by SweetPants »
I don't think so because he is running on a Raspberry. First start with upgrading to latest (beta) version and check again.
edgarhildering
SweetPants wrote:...First start with upgrading to latest (beta) version and check again.
Beta is not my favorite... As far as I know I have upgraded to the latest stable version. (And I will update the signature too, and yes, you're right: running on a Raspberry Pi... ;) )
TUYA switches
gizmocuz
Post by gizmocuz »
Upgrade to the latest beta version first to see if this is solved.
Or you can wait for a new stable version (beta renamed to stable) and expect the same behaviour
Or try a second installation ?
