Hi Guys,
I just got an new zwave sensor. The Vision ZG8101 garage door sensor.
I've got it configured as a contact switch type.
The problem I've got now is that when the sensor is in a vertical position the switch states "open". When horizontal it states "closed".
Is this a configuration issue?
Or can this value be inverted?
Vision Garage Door sensor inverted value
yvoswillens
yvoswillens
Re: Vision Garage Door sensor inverted value
problem solved. I had the sensor itself mounted the wrong way. Turned it around and now its okay.
