Hi guys,
I'm trying to find the right way to add the 3 meters (gas, electricity and water) to my domoticz dashboard.
I currently don't have any meters for this nor the hardware to do it. I live in Belgium and all 3 meters have analog readouts.
What kind of hardware would I need to get this working in an easy way in Domoticz (I don't know anything about scripting etc...) Is there an easy way, sort of plug-and-play? Something you can stick on the meters and have it wirelessly send data to domoticz that is running on my Synology?
Thanks guys!
Energy, water and gas meter
Amsterdam020
- Domoticz version: 3.5629
Re: Energy, water and gas meter
http://www.youless.nl for electricity is very easy to implement in domoticz
Just add it as hardware (https://www.domoticz.com/wiki/Hardware_Setup)
Rp3, youlesss, rfxcom, philips hue, dsb1820
joske522
Ok thanks, can it also be used for gas?
Thank you!
Thank you!
Amsterdam020
No. that is more complicated on also on my wish list. Google for "domoticz gas meter" and you find ways how to do it.
blauwebuis
- Domoticz version: current
You could also try creating your own arduino-based MySensors pulse counter. It would cost your about 10 euros in materials to create the gateway and a wireless sensor.
https://www.mysensors.org/build/pulse_power
- tcviper
New Youless LS120 is now out with P1 measurement and gas+energy:
http://youless.nl/blog.html and
http://td-er.nl/2017/03/12/nieuw-youless-ls-120/
@gizmocuz
Hopefully it will get an update in domoticz soon for support
@gizmocuz
htca
I managed to create a triple analogue readout using mysensors.
You need:
- mysensors gateway (I used a nano)
- arduino mega (or 2 nano's)
- 3 apllicable sensors (depending on your meters)
See this thread on mysensors:
https://forum.mysensors.org/topic/5048/ ... e-counters
You need:
