Z-Stick + BeNext iHome (Door Sensor+Temp+SEC)
thetiou
is it possible to have compatibility with Aeon Z-Stick and this sensor : BeNext iHome (Door Sensor+Temp+SEC)
http://www.planete-domotique.com/notice ... OORS_M.pdf
I have tested with module Zwave.me and it's fully functional,
but with the Aeon Z-Stick I can't configure him but he's detected :
- Tamper switch : ok (and responsive)
- Temp sensor : ok (but I dont know how to polling)
- Door sensor : no
- SEC sensor : no
Thank's
Erratum contact SEC reacts on the same icon the tamper switch
but no icon for the door sensor ...
- Door sensor : no
- SEC sensor : no
Thank's
- gizmocuz
Re: Z-Stick + BeNext iHome (Door Sensor+Temp+SEC)
Can you send me a PM with your log/config file?
Config/zwcfg_xxxxx.xml
Config/OZW_Log.txt
/Rob
Config/OZW_Log.txt
/Rob
thetiou
as advised I did a post on the Google group OpenZwave
https://groups.google.com/forum/%20#!%2 ... -E-sYJZOaA
and I saw a very similar post on a sensor BeNext
https://groups.google.com/forum/%20#!%2 ... zMPbQQv0-4
wait and see...
wait and see...
thetiou
another manufacturer's product as the same problem ...
http://code.google.com/p/open-zwave/iss ... rt=&id=267
thetiou
I have already said, but: there is a new door sensor in BeNext (with temperature) and id (new: type = 0004, id = 0101) is different from the old door sensor (old: type = 0004, id = 0100) it is poorly recognized as "Digital Home Systems Unknown: type = 0004, id = 0101" Digital Home Systems has an id (008a) of the same manufacturer BeNext (008a) in the "manufacturer_specific file. xml "
more on this site this new sensor is referenced with id 100 may be that the problem comes from here?
http://www.pepper1.net/zwavedb/device/149
mccharlet
I have the same problem.
I saw, the open-zwave code are updated for the new version.
It's possible to update the manufacturer_specific.xml file and all benext files ?
Best regards
Best regards
- gizmocuz
Yes, but they will be overwritten when a new release of openzwave is made.
At the moment i added a custom philio 3-1 sensor in it...
if this is working well (derrik... is it working well?
i will post the modifications on the openwave forum/issue.
If you make changes for a new device, and it is working correctly, please do the same...
There are many many zwave devices, and it's impossible to have them all supported
helping openzwave with this is the way to go
mccharlet
The new openzwave version 1.0.758 http://www.openzwave.com/snapshots/ is updated with the new BeNext sensor
Can you update domoticz with this version ?
Very thanks
Best regards
Very thanks
Best regards
- gizmocuz
This version is already in domoticz since 19 Feb.
You could try to backup your zwave configuration file, and delete the current one.
stop domoticz
cp Config/zwcfg_xxxxxx.xml Config/zwcfg_xxxxxx.bak
rm Config/zwcfg_xxxxxxx.xml
start domoticz
stop domoticz
start domoticz
mccharlet
The manufacturer_specific.xml isn't the version 1.0.758 in my raspberry. They are more diffence between the local file and the fine in version 1.0.758
By exemple this line doesn't existe in domoticz version V1.1575 (in benext section)!!!
<Product type="0003" id="0101" name="DHS-ZW-SNMT-01 Multi Sensor" config="BeNext/Molite.xml"/>
Best regards
Best regards
- Capture.JPG (11.64 KiB) Viewed 3020 times
- gizmocuz
should be solved now with the latest beta
mccharlet
Now it's OK
thetiou
great ! they aren't detected as "BeNext" but works perfectly, thank you!
- heggink
- Domoticz version: 12451
I ordered a benext door sensor. Is this the same? It's recognised (all the devices) and listed as a benext but it's not working (gets a timeout after a few mins and never works again).
There is another thread: viewtopic.php?f=17&t=7376&p=63009#p63009
H
H
DASHTICZ 🙃
P1 meter & solar panel
DASHTICZ 🙃
