Echo Dot + HA Bridge what's the next step?
StanHD
Re: Echo Dot + HA Bridge what's the next step?
Post by StanHD »
I have had a really good solid experience with V3.5.0, so thought I would upgrade to V4.0.3.
Big mistake, although all my existing devices still worked I just couldn't work out the new add device interface.
Editing existing devices just showed the entire JSON command in the first http box. I tried to add a new device from scratch, but no luck. So I have reverted to V3.5.0.
All is working great again now.
Python:- Broadlink RM2, Sonos
blackdog65
Post by blackdog65 »
Many thanks Stan,
I'll revert to 3.5.0
Without a Domoticz interface, Alexa becomes a joke telling doorstop :roll:
Sean
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
michaldobrotka
Post by michaldobrotka »
Thanks Guys,
I was just looking around whats new in 4.0 and thinking to upgrade, but, I´m rather staying at 3.5.
Domoticz on Raspi 3 and slave on ZeroW (running only with Broadlink plugin), Serial Mysensors GW on Arduino nano, Broadlink RM2, Rehau CO2 USB Stick, RF link 433 MHz, 2x Amazon Echo Dot (Controlicz), ESP2866 witk Espeasy, Sonoff
StanHD
Post by StanHD »
blackdog65 wrote:Many thanks Stan,
Sean
Yep, totally agree; However, I must say that for me with the HA-Bridge it really enhances my installation.
I'm running HA-Bridge on a "spare" RPi, (my Domoticz installation runs on a NUC under Windows), in the period I took it off line to upgrade and revert, we were pathetically going about the house asking Alexa to override lighting, turn on the TV, turn off the extract etc. none of which worked of course. We actually had to use switches ...... unbelievable :lol:
Anyway all working again now. ........... "Alexa, tell me a joke" ....... :shock:
blackdog65
Similar here except I use a cubietruck instead of a NUC.
In 3.5.0 there is
Requester Address (comma separated list)
which I assume allows only "The Kitchen Dot" to turn on the "Kitchen Lights" etc. I can't see why that's useful. What would be MUCH better would be if "The Kitchen Dot" recieved a "Turn on the lights" it turned on "Kitchen Lights" and similar for other dots in other rooms. Maybe one day ;)
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
MikeF
Domoticz version: V2022.2
Post by MikeF »
Does anyone know what the limit is in Echo for the number of Philips Hue devices you can control - which obviously will also be the limit for HA-Bridge?
I'm currently using this approach: viewtopic.php?f=38&t=15710, which emulates WeMo devices and uses a single python program. There's a limit in Echo of 14 (virtual) WeMo devices, and I've already hit this limit (on / off switches).
If the HA-Bridge limit is higher, I'll switch to that.
StanHD
Re: RE: Re: Echo Dot + HA Bridge what's the next step?
Post by StanHD »
MikeF wrote:Does anyone know what the limit is in Echo for the number of Philips Hue devices you can control - which obviously will also be the limit for HA-Bridge?
I currently have 30 entries / devices in my HA-Bridge Image
MikeF
Post by MikeF »
Got this working well! :D
I have a LightwaveRF dimmer, which has 32 steps. I discovered that I needed to use the following URL to dim it across its full range:
http://<DOMOTICZ URL:PORT>/json.htm?type=command&param=switchlight&idx=<IDX>&switchcmd=Set%20Level&level=${intensity.math(X*32/255)}
When you use intensity.math, X takes values from 0 to 255.
Similar approach would apply for dimmers with 16 & 100 steps - just replace '32' accordingly.
Users browsing this forum: palnic and 1 guest
