How to create & delete a file from dzvents?
n1c0l45
Domoticz version: V3.4834
Post by n1c0l45 »
I'm discovering DZvents and it's quite nice!
I'm using it to check my doors, but i would like to send a SMS (with gammu) if notification is needed.
I need 2 things:
1- create a tempory file with a defined text from the script (ex: door open since 5 min)
2- delete the tempory file created earlier after the code has been sent
Is it possible?
thanks
n1c0l45
Re: How to create & delete a file from dzvents?
Post by n1c0l45 »
Not possible to do that with Lua?
Egregius
Domoticz version: v2024.7
Post by Egregius »
If you don't find a solution in lua you could also use php. file_put_contents will create the file, unlink will delete it.
dannybloe
Post by dannybloe »
Well, Lua has methods to create files. Search google 'Lua create file' and you have loads of hits and examples :)
