Hello all, does anybody have this kind of Camera added to Domoticz ?
There are a lot of 720p 1Mpix IP Cameras on Aliexpress for example
http://www.aliexpress.com/item/Mini-IP- ... 3e72799e7c
or
http://www.aliexpress.com/item/Mini-IP- ... 437f8d7ed6
Maybe somebody has this cameras and can answer me if there is possibility to get snapshot and add it in Domoticz.
720p 1Mpix cheep China Camera
Re: 720p 1Mpix cheep China Camera
The second link is - I think! - the [famous] TOP-201.
You can go and learn a bit more https://www.ipcamtalk.com/showthread.ph ... -Far-!!%29.
I've got one. In Domoticz, MJPEG flux
ImageURL -> webcapture.jpg?command=snap&channel=1
but my ratio is not correct, image is a little shrink in width
Thanks @nickous for your answer. So do you think that in second link i have posted there is this "hardware" inside ?
Do you have this cam like in second post or thi one - TOP-201 Super Mini 720P HD IP-Cam ?
Thanks in advance ;]
@dise Sorry for the late answer...
I've got this one http://www.aliexpress.com/item/1280-720 ... 5,201409_5
It's a IPC_HI3518E_50H10L_S38 from Xmeye
hello @nickous thanks a lot ;] Actually i have contacted with this seller and he told me that there is no support for jpg snapshot in this camera ;( I'M confused ;] I have to check it
- Domoticz version: 2022.2
nickous wrote:@dise Sorry for the late answer...
Hello sir. I bought the same camera,but i cant get it to work with either browser or domoticz! Can you share your setup please?
Windows 10, Domoticz 14784
https://nl.aliexpress.com/item/WiFi-P2P ... 0.0.JkVXId
Just bought this one. Struggled a time to get it working under Domoticz. But finally I got it.
Ip-adres = adres of Ip-cam
Port = standard port to connect to ipcam. in my case = 81
user = login name to ip-cam
password = password to ip-cam
url = snapshot.cgi?user=USERNAME&pwd=PASSWORD (same as filled in above)
I was thinking about the camera you mentioned, but I took this one because it said it supported ONVIF. And ONVIF works with my Synology NAS. Which was also a struggle to connect by the way.... It's cheap, but takes a lot of patience to get it work.
RFXcom433e ver1009,Raspberry Pi,Domoticz v3.5877
KaKu:16c remote,dimmer,wall-sockets,sunscreenswitch
Promax:wall sockets Elro:wall sockets Somfy:RFY screens
TFA:weather station Chinese temperature sensors, smoke detectors, power switches
Users browsing this forum: Bing [Bot] and 0 guests
