Using Qubino DIN dimmer ZMNHSD1 as a switch ?
Information about specific Z-Wave devices
lec668
Domoticz version: 2021.1
Post by lec668 »
My setup :
Hardware: Raspberry Pi 3 Model B
OS: OSMC Jessie
Domoticz branch: beta
Version: 3.6555 / Build Hash: 31f858d
I successfully integrated two DIM dimmers in Domoticz.
I tried changing the parameter 5 from dimmerto switch mode, to no avail.
As per Qubino documentation, I have to chage the parameter, exclude the module, then include it again.
Doesn't work. Module stays in dimmer mode always, and is discovered as such.
Any luck using the module as a plain switch ?
Mat2Vence
Domoticz version: 3.7449
Re: Using Qubino DIN dimmer ZMNHSD1 as a switch ?
Post by Mat2Vence »
I am interested on adding such module in my setup. Did you finally to make it work un On/Off mode?
