device last update wrong - is this a bug?
renerene
Post by renerene »
I've bought a contact switch that sends ON signals to two sensors in Domoticz. When writing a Lua scipt to set a variable (open/close) I found this strange bug. For one of the two devicees the update time is correct under 'setup -> devices' and 'switches' but wrong in the 'show current states' LUA section.
Is this a bug?
(in the second screen shot the wrong sensor is marked, but you get the idea)
jvdz
Domoticz version: 4.107
Re: device last update wrong - is this a bug?
Post by jvdz »
What does the log show for this device?
Jos
renerene
Post by renerene »
here is the log:
Siewert308SW
Domoticz version: Stable
Post by Siewert308SW »
If you run the script again does the time update?
Looks like it aint triggered.
Setup:
- DS923+ Docker
Domoticz Latest Stable
Mosquitto / ZwaveJSUI @ Aeotec Z-Stick Gen5+ / PiHole Unbound
P1 USB Gas/Power, HW watermeter
- A lot of Zwave switches, contacts, plugs, smoke/Co2 ect
- DiY 7.5kWh Solar Storage @ GitHuB
renerene
Post by renerene »
sometime the lua table (button 'show current states, bottom right in events) updates the values, but the shown table is not in sync with the table under 'devices'. The update time under 'devices' is correct.
Here another example. Time between screenshots is ca. 5 secondes,with no fysical change of the sensor in the meanwhile
This script gets triggered after every sensor state, verything ok in the log.
O've tried both otherdevices_lastupdate[sensor] and devicechanged methods, but because of the sync problem they do not work reliable.
so = 'deurBrittOpen'
sc = 'deurBrittClosed'
tc = next(devicechanged)
v = tostring(tc)
if v ==so then print ('deur open')
elseif v==sc then print ('deur dicht') end
I've succesfully made ca. 20 LUA scripts, this is the first time this has happened to me. It is the first time is use Lightning4 protocol, which is needed to read this KeruiD026 doorswitch.
