OpenWeatherMap API Device Location Issue
OpenWeatherMap location fails to update for me. I've tried several APIs and same result. Inputting a custom zip code string for location or lat long still just reverts back to the default location after clicking update. Help?
Re: OpenWeatherMap API Device Location Issue
I think I do have the same trouble here, or a similar : when I put my location in Domoticz Open Weather Map hardware, it always set it back to "lat=53.40&lon=14.58".
Has anybody fixed this issue ?
(darksky is working ok, and weather underground too, but open weather map seems to have a better accuracy for my location)
RPI3B (Domoticz 4.9700 + ~60 scripts) + RFXtrx433E (fw1020) + Z-Stick Gen5 + MySensors / RPI2B+ (RasPlex)
x1 Eth. wired tablet
x8 T/H Oregon / x1 T/H Bresser
x7 heaters / x2 QUBINO "Flush 1 relay"
x10 plugs / x15 contacts
x4 fibaro / x1 PIR
x4 fibaro / x1 PIR
I answer to myself : following update to version 3.6561 (beta), it is working fine now.
Thank you if someone fixed it !
If not, it works by a miracle !
x4 fibaro / x1 PIR
x4 fibaro / x1 PIR
