Floorplan + Dimmer
Hellfish
Floorplan + Dimmer
Post by Hellfish »
i have some problems with my dimmer on the floorplan. By pressing the symbol i can only switch them on and off. Ive found no way to set a %-level within the floorplan. On the normal menu everything works fine.
Any ideas whats wrong?
Cheers
Hellfish
Dnpwwo
Re: Floorplan + Dimmer
Post by Dnpwwo »
@Hellfish,
Does the device info popup not work or are you not seeing it at all? Are you using it on a PC or tablet?
You should be able to hover over the icon and get a popup with a slider on it (touch and hold on a tablet).
oldfantome
Post by oldfantome »
the same probleme
on my PC ,tablette and smartphone.
domoticz Version: 4.9700 , raspberry 2b ,raspbian
I havent the slide on my dimmer in floorplan
look the dimmer "salon"
Sorry for my bad English (I'm french)
oldfantome
help
I don't find the solution :o
felix63
Domoticz version: 2020.1
Post by felix63 »
I think it doesn't work because you are using a custom icon instead of the default.
