Change size of floorplan icons
Mikey
Post by Mikey »
In my floorplan, the icons of the different devices are really small. It is almost not readable. Is there a possibiltiy to change the size of the device icons in the floorplan?
mongoose
Re: Change size of floorplan icons
Post by mongoose »
Just edit the floorplan.jpg file and you can scale the icons from there
Mikey
Post by Mikey »
Could you explain me in a little more detail, how to do that? Thanks a lot
StanHD
Post by StanHD »
Goto:-
Setup > More Option > Plans > Floorplan
Then select your plan from the top group.
Then click "Edit"
You should get this:-
Hope it helps ;)
Python:- Broadlink RM2, Sonos
Mikey
Post by Mikey »
You are a genius, that worked just perfect. I tried such a long time and it was so easy. Thank you very much :D
