# m h dom mon dow command
#*/10 * * * * sudo python /home/pi/domoticz/scripts/python/check_device_online_$
@reboot python /home/pi/domoticz/scripts/python/plex.py &
*/5 * * * * /home/pi/domoticz/scripts/python/plex.py
#!/usr/bin/python
# -*- coding: utf-8 -*-
from __future__ import division
import traceback
import sys
import datetime
import time
import os
import urllib, urllib2, hashlib,subprocess
from xml.etree import ElementTree as ET
ErrorCount = 0
#general Script settings
plex_Interval = 5 # Poll Interval. The Plex Server updates the session status every 10 seconds. Leave at 5 to not mis any state change.
plex_ShowPlayProgress = True
plex_AutoClearPlayLog = True # Should be enabled when showing Play Progress
plex_AutoCreateUserVariables = True # Automatically create a user variable for each Client listed under dom_PlexPlayers
plex_ViewOffsetTimeout = 15 # In seconds.
plex_MaxErrorCount = 3 # number of consecutive errors until Plex is considered Offline
#RunState values (for user variable)
plex_ServerOffline = -1
plex_Idle = 0
plex_Video_Playing = 1
plex_Video_Paused = 2
plex_Video_Stopped = 3
plex_Video_Buffering = 4
plex_Audio_Playing = 11
plex_Audio_Paused = 12
plex_Audio_Stopped = 13
plex_Audio_Buffering = 14
#Plex Server Settings
plexIP = '192.168.0.142'
plexPort = '32400' # (default port = 32400)
plexToken = '' # (Fill in when using Plex Home. To Retrieve Token: https://support.plex.tv/hc/en-us/articles/204059436-Finding-your-account-token-X-Plex-Token)
#domoticz settings
domoticz_host = '192.168.0.148'
domoticz_port = '8080'
domoticz_url = 'json.htm'
#Translation Array - It's also possible to specify custom search strings. Place them at the beginning of the array.
transl_search = ['Playing','Stopped','Buffering','Paused','Video','Movie','Episode','Clip','Audio','Slideshow']
transl_replace = ['','','','','','','','','',''] #place replacement string on the same index as the search string. empty strings are not processed.
#Plex Players Settings - This script handles multiple players
dom_PlexPlayers = ['OpenELEC-PHT','Jasper-TPC'] #Players not on this list will be ignored
dom_PlexPlayInfo_ID = ['24','30']
dom_PlexPlayState_ID = ['',''] # Name of User Variable. Is overwrriten when plex_AutoCreateUserVariables=True
#Various Variables
plex_TimeLastUpdate = ""
plex_LastOffsetUpdate = [] # of loop iterations
plex_LastOffset = []
plex_PreviousState = []
plex_PreviousTitle = []
plex_AlreadyIdle = []
#building url
requestURL = 'http://'+ plexIP + ':' + plexPort + '/status/sessions/?X-Plex-Token=' + plexToken
#Ensure equal list sizes
while len(dom_PlexPlayInfo_ID)<len(dom_PlexPlayers):
dom_PlexPlayInfo_ID.append('-1')
while len(dom_PlexPlayState_ID)<len(dom_PlexPlayers):
dom_PlexPlayState_ID.append('-1')
while len(plex_LastOffsetUpdate)<len(dom_PlexPlayers):
plex_LastOffsetUpdate.append(1)
while len(plex_LastOffset)<len(dom_PlexPlayers):
plex_LastOffset.append(1)
while len(plex_PreviousState)<len(dom_PlexPlayers):
plex_PreviousState.append('0')
while len(plex_PreviousTitle)<len(dom_PlexPlayers):
plex_PreviousTitle.append('0')
while len(plex_AlreadyIdle)<len(dom_PlexPlayers):
plex_AlreadyIdle.append(False)
while len(transl_replace)<len(transl_search):
transl_replace.append('')
# create play Status user variable for each client
if plex_AutoCreateUserVariables:
for client in dom_PlexPlayers:
try:
name = "PLEX STATUS [" + client + "]"
url = "http://" + domoticz_host + ":" + domoticz_port + "/" + domoticz_url+ "?type=command¶m=saveuservariable&vname=" + name + "&vtype=Integer&vvalue=" + str(plex_Idle)
url = urllib.quote(url.encode('utf-8'), safe="%/:=&?~#+!$,;'@()*[]'")
urllib2.urlopen(url , timeout = 5)
idx = dom_PlexPlayers.index(client)
dom_PlexPlayState_ID[idx] = name
except Exception:
print 'Connection Error'
pidfile = sys.argv[0] + '_' + plexIP + '.pid'
if os.path.isfile( pidfile ):
if (time.time() - os.path.getmtime(pidfile)) < (float(5) * 3):
print datetime.datetime.now().strftime("%H:%M:%S") + "- script seems to be still running, exiting"
print datetime.datetime.now().strftime("%H:%M:%S") + "- If this is not correct, please delete file " + pidfile
sys.exit(0)
else:
print datetime.datetime.now().strftime("%H:%M:%S") + "- Seems to be an old file, ignoring."
else:
open(pidfile, 'w').close()
def translate(playstring):
returnstring = playstring
for idx in range(0, len(transl_search)):
if transl_replace[idx]!='':
returnstring = returnstring.replace(transl_search[idx],transl_replace[idx])
print returnstring;
return returnstring;
while 1==1:
try:
#call session url
ProcessedIDs=[]
test = urllib2.urlopen(requestURL,timeout = 5).read()
root = ET.XML(test)
#Video Support
for video in root.findall('Video'):
# Get Attributes for each player
player = video.find('Player').attrib['title']
state = video.find('Player').attrib['state']
parenttitle = video.get('grandparentTitle')
videotitle = video.get('title')
videotype = video.get('type')
videoduration = video.get('duration')
viewOffset = video.get('viewOffset')
PlayProgress=''
if plex_ShowPlayProgress and videoduration is not None:
durTotalSeconds = long(long(videoduration) / 1000)
durSeconds = int(durTotalSeconds % 60)
durTotalSeconds /=60
durMinutes = int(durTotalSeconds % 60)
durHours = int(durTotalSeconds)
if viewOffset is not None:
runTotalSeconds = long(long(viewOffset) / 1000)
runSeconds = int(runTotalSeconds % 60)
runTotalSeconds /=60
runMinutes = int(runTotalSeconds % 60)
runHours = int(runTotalSeconds)
else:
runSeconds=0
runMinutes=0
runHours=0
PlayProgress= ' (' + str(runHours) + ':' + str(runMinutes).zfill(2) + ':' + str(runSeconds).zfill(2) + '/' + str(durHours) + ':' + str(durMinutes).zfill(2) + ':' + str(durSeconds).zfill(2) + ')'
else:
PlayProgress=""
PlayString = ""
StateChange = 0
PlayerID = dom_PlexPlayers.index(player) if player in dom_PlexPlayers else -1
if PlayerID >= 0: #only process players that are on the list
plex_AlreadyIdle[PlayerID] = False
try:
# Check if there is progress
if (viewOffset>plex_LastOffset[PlayerID] and state=="playing") or (videotitle!=plex_PreviousTitle[PlayerID]):
plex_LastOffsetUpdate[PlayerID] = 0
elif viewOffset == plex_LastOffset[PlayerID]:
plex_LastOffsetUpdate[PlayerID] += 1
if plex_LastOffsetUpdate[PlayerID] >= int(plex_ViewOffsetTimeout/plex_Interval) and state == "playing":
state = "stopped"
if plex_PreviousState[PlayerID] == state:
StateChange = 0
else:
StateChange = 1
plex_PreviousState[PlayerID]=state
plex_PreviousTitle[PlayerID] = videotitle
if videotype == 'movie':
PlayString = state.capitalize() + " Movie: " + videotitle + PlayProgress
elif videotype =='episode':
PlayString = state.capitalize() + " Episode: " + parenttitle + " - " + videotitle + PlayProgress
elif videotype =='clip':
PlayString = state.capitalize() + " Clip: " + parenttitle + " - " + videotitle + PlayProgress
else:
PlayString = state.capitalize() + "Video " + ": " + videotitle + PlayProgress
#uploading log message to domoticz
PlayString = urllib.quote(translate(PlayString).encode("utf-8"))
if StateChange == 1:
url = "http://" + domoticz_host + ":" + domoticz_port + "/" + domoticz_url + "?type=command¶m=addlogmessage&message=" + PlayString
statusValue = 0
if state == "playing":
statusValue = plex_Video_Playing
elif state == "paused":
statusValue = plex_Video_Paused
elif state == "stopped":
statusValue = plex_Video_Stopped
elif state =="buffering":
statusValue = plex_Video_Buffering
#uploading values to domoticz
url = "http://" + domoticz_host + ":" + domoticz_port + "/" + domoticz_url + "?type=command¶m=udevice&idx=" + dom_PlexPlayInfo_ID[PlayerID] + "&nvalue=0&svalue=" + PlayString
url = ("http://" + domoticz_host + ":" + domoticz_port + "/" + domoticz_url + "?type=command¶m=updateuservariable&vname=" + dom_PlexPlayState_ID[PlayerID] + "&vtype=integer&vvalue=" + str(statusValue))
urllib2.urlopen(url,timeout = 5)
if plex_LastOffset[PlayerID] != viewOffset or state=="stopped":
if plex_AutoClearPlayLog:
url = "http://" + domoticz_host + ":" + domoticz_port + "/" + domoticz_url + "?type=command¶m=clearlightlog&idx=" + dom_PlexPlayInfo_ID[PlayerID]
plex_LastOffset[PlayerID] = viewOffset
ProcessedIDs.append(PlayerID)
except Exception,e:
print 'IDLE'
print e
print traceback.print_exc()
url = ("http://" + domoticz_host + ":" + domoticz_port + "/" + domoticz_url+ "?type=command¶m=udevice&idx=" + dom_PlexPlayInfo_ID[PlayerID] + "&nvalue=0&svalue=No%20Media%20Playing")
pass
#Audio Support
for audio in root.findall('Track'):
player = audio.find('Player').attrib['title']
state = audio.find('Player').attrib['state']
parenttitle = "Unknown"
parenttitle = audio.get('grandparentTitle')
audiotitle = audio.get('title')
audioduration = audio.get('duration')
viewOffset = audio.get('viewOffset')
PlayProgress=''
if plex_ShowPlayProgress:
durTotalSeconds = long(long(audioduration) / 1000)
else:
runSeconds=0
runMinutes=0
runHours=0
else:
PlayProgress=""
PlayString = ""
StateChange = 0
try:
if (viewOffset>plex_LastOffset[PlayerID] and state=="playing") or (audiotitle!=plex_PreviousTitle[PlayerID]):
state = "stopped"
StateChange = 0
else:
StateChange = 1
plex_PreviousTitle[PlayerID] = audiotitle
PlayString = state.capitalize() + " Audio: " + parenttitle + " - " + audiotitle + PlayProgress
PlayString = urllib.quote(translate(PlayString).encode('utf-8'))
statusValue = 0
statusValue = plex_Audio_Playing
statusValue = plex_Audio_Paused
statusValue = plex_Audio_Stopped
statusValue = plex_Audio_Buffering
if plex_LastOffset[PlayerID] != viewOffset:
except Exception,e:
print 'IDLE'
print e
pass
for photo in root.findall('Photo'):
player = photo.find('Player').attrib['title']
state = photo.find('Player').attrib['state']
parenttitle = photo.get('parentTitle')
phototitle = photo.get('title')
PlayString = ""
StateChange = 0
try:
StateChange = 0
else:
StateChange = 1
plex_PreviousTitle[PlayerID] = phototitle
PlayString = state.capitalize() + " Slideshow: " + parenttitle + " - " + phototitle
statusValue = 0
except Exception,e:
print 'IDLE'
pass
#set play status to IDLE
for i in range(0, len(dom_PlexPlayers)):
if i not in ProcessedIDs and plex_AlreadyIdle[i] == False:
print 'IDLE'
url = ("http://" + domoticz_host + ":" + domoticz_port + "/" + domoticz_url+ "?type=command¶m=udevice&idx=" + dom_PlexPlayInfo_ID[i] + "&nvalue=0&svalue=No%20Media%20Playing")
url = ("http://" + domoticz_host + ":" + domoticz_port + "/" + domoticz_url+ "?type=command¶m=updateuservariable&vname=" + dom_PlexPlayState_ID[i] + "&vtype=integer&vvalue=0")
plex_AlreadyIdle[i] = True
ErrorCount = 0
except Exception,e:
ErrorCount+=1
if ErrorCount == plex_MaxErrorCount:
print 'PLEX OFFLINE'
if plex_AlreadyIdle[i] == False:
url = ("http://" + domoticz_host + ":" + domoticz_port + "/" + domoticz_url+ "?type=command¶m=updateuservariable&vname=" + dom_PlexPlayState_ID[i] + "&vtype=integer&vvalue=" + str(plex_ServerOffline))
pass
time.sleep (plex_Interval)
"http://" + domoticz_host + ":" + domoticz_port + "/" + domoticz_url + "?type=command¶m=updateuservariable&vname=" + dom_PlexPlayState_ID[PlayerID] + "&vtype=integer&vvalue=" + str(statusValue))Code: Select all
plex_Interval = 4 # Poll Interval. The Plex Server updates the session status every 10 seconds. Leave at 5 to not mis any state change.
plex_ViewOffsetTimeout = 20 # In seconds.
plex_MaxErrorCount = 3 # number of consecutive errors until Plex is considered OfflineIve given it 775 rights, I can see in "top" that the script is running, the IDX for flex is updating, but not the Variables.racquemis wrote:Okay, so the script runs fine executed from putty but not when run from a crontab, you have given the script 775 rights? (execute rights)
*/10 * * * * /home/pi/domoticz/scripts/python/plex.py > /home/pi/domoticz/scripts/python/plex.log 2>&1Users browsing this forum: Google [Bot] and 1 guest
