You should have something like this to :checkdiz wrote:i got this:
usbcore: registered new interface driver ch341
USB Serial support registered for TI USB 3410 1 port adapter
USB Serial support registered for TI USB 5052 2 port adapter
usbcore: registered new interface driver ti_usb_3410_5052
ti_usb_3410_5052: v0.10:TI USB 3410/5052 Serial Driver
i saw one error, but don't know if related:
EXT3-fs (md0): error: couldn't mount because of unsupported optional features (240)
usb 6-2: ch341-uart converter now attached to ttyUSB0
If you look in Control Panel ->Info Center you should see:
USB device HL-340 USB-serial adapter .....
If you use USB HUB, try with out.
You can also check if you have this file in folder /usr/lib/modules
usbserial.ko
