Is there a more complete documentation set available that explains what happens (what each part of a scirpt line does) when a (for instance) temp/hum/bar sensor is splitted? I don't understand what those magic [%+xyz] etc means
Also, to update a multiple value sensor, like the p1 smart meter, I don't understand the way those commands are built up and they seem to differ between sensors. What do things like |0| mean and ..sensorname.
In a summary, is there, beside the JSON Wiki page also a LUA (wiki) page that explains per sensor proper usage? It would be more then welcome, since I am comparing scripts all the time and having no clue what I am actually doing.[sub?[/sub]
'How-to' for LUA Split sensor data and fill 'multi-sensor'
antares
Re: 'How-to' for LUA Split sensor data and fill 'multi-sensor'
I would appreciate some documentation / explanation on that as well. Thanks for asking @jake.
Nautilus
For the "magic" character I suggest looking up some general LUA documentation, nothing Domoticz specific there
There is also wiki page for events:
https://www.domoticz.com/wiki/Events, check especially:
AndTo modify an otherdevice value, you should use commandArray['UpdateDevice']='idx|nValue|sValue' where idx is the device index, nValue and sValue the values to modify (see json page for details - Domoticz API/JSON URL's)
If there is some specific script you need help with, then I'd say the first thing would be to post the actual script and specify which parts need explaining. I'm not using P1 myself so not sure if I can give any advice there but I'm sure there are others here who can answer once they know the question...Some valid examples:
commandArray['Switch']='On'
commandArray['Scene:Livingroom']='On'
commandArray['Group:Kitchen']='Inactive'
commandArray['Keyfob']='Group On'
commandArray['DimmableDevice']='Set Level 50'
commandArray['Selector']='Set Level: 50'
commandArray['SendNotification']='subject#body#0'
commandArray['SendEmail']='subject#body#[email protected]'
commandArray['OpenURL']='www.yourdomain.com/api/movecamtopreset.cgi'
commandArray['Blinds']='On RANDOM 30'
commandArray['Porch Light']='On FOR 2'
commandArray['Variable:MyVar']='Some value'
commandArray['Variable:MyVar']='Some value AFTER 3'
commandArray[textDeviceIdx] = { ['UpdateDevice'] = textDeviceIdx..'|0|'..'some text' }
commandArray[tempDeviceIdx] = { ['UpdateDevice'] = tempDeviceIdx..'|0|'..temp }
commandArray[tempHumDevIdx] = { ['UpdateDevice'] = tempHumDevIdx..'|0|'.. temp ..';'.. hum ..';'.. hum_stat }
