Does anyone know how I can set the Aeotec ZW098 LED Bulb to cold white without having to do it from the z-wave control panel?
Via mqtt/json is fine as well since I use node red as well
tnxs
set warm/cold white on Aeotec ZW098 LED Bulb
strelniece
- Domoticz version: 3.8153
andersbz
Re: set warm/cold white on Aeotec ZW098 LED Bulb
Manually Changing LED Bulb’s color.
LED Bulb can fill your room with multiple shades of white and an additional 16 million different colors. It’s possible to manually select some of these without the use of your Z-Wave gateway. To do this;
1. Toggle LED Bulb off, on, off, on in quick succession via its wall switch. LED Bulb has now entered color cycle mode and will cycle through the following colors: warm white, cold white, red, orange, yellow, green, cyan, blue and purple.
2. When the color cycle arrives at the color you’d like to select, toggle off LED Bulb via the wall switch. The visible color will be set as your bulb’s default.
strelniece
well, yes, but I mean from domoticz, the manual version I know quite well and it is rather tedious to go trough. The whole point of having an automated system is that it is, hm, automatic
andersbz
Sorry misunderstood
strelniece
det är lungt
Users browsing this forum: madpatrick and 1 guest
