Events not working after update to 3.5837
BazsoDombiAndras
Domoticz version: v4.10717
Re: Events not working after update to 3.5837
Post by BazsoDombiAndras »
I have the same problem in stable version 3.6334: LUA scripts running fine, Blockly events not triggered anymore.
Restarting the Raspberry Pi on which Domoticz runs does NOT fix the issue.
I have recently added an RfxTrx433E to my Domoticz and I see that others (simon_rb) have also done RfxTrx433E related changes before getting this bug. Could it somehow be cause by RfxTrx433E? disabling the RfxTrx433E in Domoticz and even restarting the Raspberry Pi after it does NOT solve the problem.
BazsoDombiAndras
Updated to the latest beta: 3.6478.
The problem still exists.
chatainsim
Domoticz version: v4.11307
Post by chatainsim »
BazsoDombiAndras wrote:Updated to the latest beta: 3.6478.
I have the same problem with 3.6478.
I'm not using a RPI. Only a server with Ubuntu.
Siewert308SW
Domoticz version: Stable
Post by Siewert308SW »
BazsoDombiAndras wrote:I have the same problem in stable version 3.6334: LUA scripts running fine, Blockly events not triggered anymore.
No problems here on the latest beta on a Pi3.
But seems blocky is down if Lua is working.
Otherwise i would check on which usb port the rfx is running and what domoticz runs.
Setup:
- RPi4 - Domo Stable / Aeotec Z-stick7 / PiHole Unbound Gemini
- RPi4 - PiHole / PiVPN Unbound Gemini
- Synology DS923+ / DS218j
- P1 Gas/Power, SmartGateway watermeter
- Fibaro switches, contacts, plugs, smoke/Co2 ect
- rootfs @ USB HDD
chatainsim
I've restarted my server and it's working fine now.
harolds
Post by harolds »
I had to run the 'updaterelease' script to fix this problem. After that I used 'updatebeta' but it looked like I was still on the beta after running 'updaterelease'. Now I see message from my LUA scripts again. So looks like that fixed it.
