Humidity graph and 100%
Clemen
Wouldn't it be better that the humidity graph max value was 100% and the line was in top of the grap and not the bottom. The humidity can never go pass 100% so showing values like 103% and 108% on graph is not the best solution.
Xztraz
Re: Humidity graph and 100%
Or even 140%
100% should be max limit and 0 min limit.
and i think minimum span should be 20% at least. otherwise small changes would fluctuate a lot if humidity is quite stable
- 140percent.PNG (75.78 KiB) Viewed 658 times
Xztraz
This is due to a bug in highcharts and hard to resolve keeping the humidity scale dynamic. But it should be a bit better now. Thanks gizmodus for guiding me to the right part of the code
