X10 Dimmers implementation
Persisto
Domoticz version: 2.4386
Post by Persisto »
I know X10 is not respected hardware (I agree, but that is what I and a lot of other DOmoticz users have) and the X10 protocol is not an example of clarity but
PL A1 xdim xx
(where 0 =< xx <= 63) works on Marmitek LW11 modules -the most common I believe- and would be fairly easy to implement:
Liberate the slider on the png, send " xdim & int(slidervalue *.63)" to the dimmer when it changes
I've made a hack: http://www.domoticz.com/forum/viewtopic ... 23&t=15575 for which Domoticz reports non-existing Mochad errors :)
I'd be happy to test in beta if that is what it takes.
Plailly France
X10 Marmitek + Ebode for lights and blinds + CM15
mochad
Domoticz, Domoticz Lite, Geofence
Raspberry Pi III
franzelare
Re: X10 Dimmers implementation
Post by franzelare »
I do see the code when changing a dimmer status manually on a 2 way dimmer being received by domoticz but not able to process:
like this for different raw levels of the same dimmer
2017-01-21 11:17:34.572 Error: Mochad: Cannot decode 'Rx PL HouseUnit: G7 Func: Ext code 1, data, control Data: 2D Command: 31'
2017-01-21 11:18:38.366 Error: Mochad: Cannot decode 'Rx PL HouseUnit: G7 Func: Ext code 1, data, control Data: 2E Command: 31'
2017-01-21 11:19:12.323 Error: Mochad: Cannot decode 'Rx PL HouseUnit: G7 Func: Ext code 1, data, control Data: 20 Command: 31'
so the dimmer level is in the control data part
Persisto
Post by Persisto »
@franzelare Maybe the X10 dimmer issue can be solved step by step.
Implementing what I propose, solves the problem of dimming: Setting the dimmer slide to 50% will set the lamp to 50% (or as near as it would using any other hardware.) which would be a big step.
Your readback of 2 way dimmers, if and when a solution is clearly identified, can maybe dealt with as a follow up
Plailly France
mochad
Raspberry Pi III
