Domoboard - Bug reports
Domoboard is a dashboard for Domoticz based on Python Flask.
Moderators: leecollings, wez3
Forum rules
Before posting here, make sure you are using the latest Beta or Stable version.
In order to fix issues or add features these have to be reported on the Domoboard Github pages.
This makes it possible to keep track of issues/features on a centralized place.
Refer to the issue of the github tracker when possible.
This subforum is meant to discuss issues and/or feature requests, or anything else related to Domoboard.
wez3
Post by wez3 »
This topic is used to discuss bug reports.In order to fix issues or add features these have to be reported on one of the the Domoboard Github pages:
https://github.com/wez3/domoboard
https://github.com/wez3/domoboard-plugins
wez3
RFAH
Domoticz version: 3.6395
Re: Domoboard - Bug reports
Post by RFAH »
I have created a group in Domoticz which switch on or off all lights in the living room.
(The group exists of On/off switches and dimmers)
If one of the lights is on, Domoticz shows the term "mixed".
If all lights are off, Domoticz shows the term "Off"
And if all the lights are on, Domoticz shows the term "On".
But when i create a top_tile in Domoboard of that group, the group always shows a percentage.
(No matter what the status is in Domoticz.) I did expect the values On, Off and Mixed, like Domoticz does.
Is this a bug or the expected behaviour?
Kind regards,
René
(and thanks for creating Domoboard)
squandor
Domoticz version: 3.5837
Post by squandor »
Could you try to use the Status key in the config:
Counter Woonkamer = 145, icon, Status
RFAH
Post by RFAH »
squandor,
I changed my config accoording to your advice, but no luck.
The icon is added to the tile and i see the text Status for a brief moment, but than i see the percentage again.
a part of my config looks like:
    [[[Verlichting]]]
      Woonkamer Verlichting = 118
      Woonkamer verlichting group = 1, info, Status
It is part of my top_tiles[Verlichting] section
I also tried status with no captital, but that didn't do the trick.
Thanks in advance,
René
squandor
Post by squandor »
ah now i see.
The problem is that Scenes and Groups have different idx's so the value that you get is from the idx which corresponds with an device idx.
I will add it to the issues on GitHub because we don't support this feature in the top tiles right now.
RFAH
Post by RFAH »
squandor,
Thanks for your help.
The percentage is indeed of an another idx.
Unfortunally i can not code, but if it needs to be tested i will be happy to do so.
Thanks again,
René
Snowtiger
Domoticz version: 4.10915
Post by Snowtiger »
The Wunderground, Condition is loading and gives an image, only the max and min values of temperature are always equal to the current temperature, maybe wrong vars selected ;)
squandor
Post by squandor »
Snowtiger wrote:The Wunderground, Condition is loading and gives an image, only the max and min values of temperature are always equal to the current temperature, maybe wrong vars selected ;)
Hmm could be an problem indeed ;) i will check it later in the evening
jaccov
Post by jaccov »
Problem with afvalwijzer plugin.
I installed the afvalwijzer plugin, Domoboard doesn't start anymore
Error occured during loading imports for the plugin afvalwijzer: No module named BeautifulSoup. Install it with 'easy_install BeautifulSoup' or 'pip install BeautifulSoup'
I installed BeautifulSoup by
pi@Domoticz:~/domoboard $ sudo easy_install BeautifulSoup
Searching for BeautifulSoup
Best match: BeautifulSoup 3.2.1
Processing BeautifulSoup-3.2.1-py2.7.egg
BeautifulSoup 3.2.1 is already the active version in easy-install.pth
Using /usr/local/lib/python2.7/dist-packages/BeautifulSoup-3.2.1-py2.7.egg
Processing dependencies for BeautifulSoup
Finished processing dependencies for BeautifulSoup
Now I start Domoboard, but still have the same problem, what is wrong.
squandor
Post by squandor »
Did you start domoboard usong virtualenv by any chance?
jaccov
Post by jaccov »
Thanks for the replay, but not familiar with virtualenv, how should i do that?
squandor
Post by squandor »
Well in that case how did you install domoboard? Did you use the bash install?
squandor
Post by squandor »
Or do you have an bin folder in you're domoboard folder?
jaccov
Post by jaccov »
sudo curl -L https://www.domoboard.nl/install | bash
yes I have the bin directory
squandor
Post by squandor »
Than you should install the beautifulsoup module using the command bin/pip install BeautifulSoup
squandor
Post by squandor »
You are using an virtualenv which means that domoboard is running in an python environment in that folder and not of the os itself. So every time when you want to install an module you must use the pip version of you're environment which can be found in the bin folder
jaccov
Post by jaccov »
pi@Domoticz:~/domoboard/bin $ sudo pip install BeautifulSoup
Requirement already satisfied (use --upgrade to upgrade): BeautifulSoup in /usr/local/lib/python2.7/dist-packages/BeautifulSoup-3.2.1-py2.7.egg
Cleaning up...
Still not running, I did't try it with virtualenv..yet
squandor
Post by squandor »
And if you try you're command with --upgrade?
jaccov
Post by jaccov »
Cleaning up...
pi@Domoticz:~/domoboard/bin $ sudo pip install BeautifulSoup --upgrade
Requirement already up-to-date: BeautifulSoup in /usr/local/lib/python2.7/dist-packages/BeautifulSoup-3.2.1-py2.7.egg
Cleaning up...
the same
squandor
Post by squandor »
And how do you start domoboard and what does it says exactly
