@waaren: great script BUT, I have a bunch of zwave door sensors that have a 12h wakeup. Unfortunately, lastupdate does not reflect the wakeup but the door state. When querying domoticz, I see both dates but your script (i.e. dzventz) only reports the update state.
Ideally, I would want to monitor all battery devices. Whilst I already monitor battery states, these sometimes drop too fast in order to be correctly reported on
Here's the device response from domoticz. If we could get the first lastupdate from dzvents then would that be the device wakeup timer?
"Description" : "BeNext Door Sensor",
"HaveUserCodes" : false,
"HomeID" : 3663738776,
"IsPlus" : false,
"LastUpdate" : "2018-03-31 12:33:14",
"Manufacturer_id" : "0x008a",
"Manufacturer_name" : "BeNext",
"Name" : "Zijdeur Sensor",
"NodeID" : 33,
"PollEnabled" : "false",
"Product_id" : "0x0101",
"Product_name" : "Door Sensor",
"Product_type" : "0x0004",
"State" : "Sleeping",
"Version" : 4,
"config" : [
"LastUpdate" : "2018-03-29 21:27:17",
"help" : "Set all configuration values to default values (factory settings).",
"index" : 1,
"label" : "Set to Default",
"type" : "byte",
"units" : "",
"value" : "255"
"help" : "Configure what the external contact sends when triggered. (Default: 0)",
"index" : 2,
"label" : "External Contact",
"list_items" : 2,
"listitem" : [
"Send a alarm report with type 2.",
"Send a Basic set frame to all nodes in association group 2."
"type" : "list",
"units" : "",
"value" : "Send a alarm report with type 2."
"help" : "Is not used but can still be set and requested.",
"index" : 3,
"label" : "Not used",
"type" : "byte",
"units" : "",
"value" : "0"
"index" : 4,
"type" : "byte",
"units" : "",
"value" : "0"
"help" : "To configure the operating mode. (Default: 1)",
"index" : 5,
"label" : "The Mode",
"type" : "byte",
"units" : "",
"value" : "1"
"help" : "A signed integer to determine the offset of the temperature. (Default: 0)",
"index" : 6,
"label" : "Temperature offset",
"type" : "int",
"units" : "",
"value" : "0"
"help" : "Debounce time when the external contact is opened. (Default: 0)",
"index" : 7,
"label" : "Extern Contact Debounce ON",
"type" : "byte",
"units" : "",
"value" : "0"
"help" : "Debounce time when the external contact is opened. (Default 0)",
"index" : 8,
"label" : "Extern Contact Debounce OFF",
"type" : "byte",
"units" : "",
"value" : "0"
"help" : "A delay from the wake up time to give the external contact a chance to change his status. (Default 0, value * 100 ms, 0 - 25,5 seconds)",
"index" : 9,
"label" : "Wake up delay",
"type" : "byte",
"units" : "",
"value" : "0"
"LastUpdate" : "2018-03-29 21:35:08",
"help" : "",
"index" : 2000,
"label" : "Wake-up Interval",
"type" : "int",
"units" : "Seconds",
"value" : "7200"
"idx" : "18"
