Can't update virtual voltage sensor after Domoticz update
marin849
Domoticz version: 2.4xxx
Post by marin849 »
After compiling the latest version my voltage sensors no longer update. I dont know which version I hade before, from April I think.
I am posting in this format
/json.htm?type=command&param=udevice&idx=IDX&nvalue=0&svalue=VOLTAGE
http://pi2.lyan.local:8080/json.htm?type=command&param=udevice&idx=244&nvalue=0&svalue=240.1
Results in:
   "status" : "OK",
   "title" : "Update Device"
But the sensor is still not updated??
BazsoDombiAndras
Domoticz version: v4.10717
Re: Can't update virtual voltage sensor after Domoticz update
Post by BazsoDombiAndras »
I have updated Domoticz a few days ago to version 3.6334 and I have the same problem. I can update any virtual device, except the voltage sensors.
I do it like this:
http://MyDomoticzServer:8080/json.htm?type=command&param=udevice&idx=71&nvalue=0&svalue=27.16
I get this response:
   "status" : "OK",
... but the virtual voltage sensor is not updated!
Why is this not working in the new versions? In v2.40 it was working fine.
BazsoDombiAndras
I eventually figured out that newly added virtual voltage sensors can be updated, the old ones not. So I removed the old virtual voltage sensors and added new ones instead (the replace functionality did not work). Unfortunately this means that I've lost 2 years worth of data for my solar panels and batteries. That's really frustrating...
