Pushbullet notification only show header
tyho
Post by tyho »
Hello everyone,
I am new to domoticz and i have a question ^^:
I use pushbullet for push notification on my iphone and on chrome (PC).
I have added my smart meter to my raspberry and i want to get a notification when i use 5000W+
My problem is, i see only the header called Domiticz. So my push notifications on my login/home screen look like:
Pushbullet
Domoticz
If i open the message it shows also "Your usage is ***** watt.", but not on my login/home screen
On Chrome it shows:
Pushbullet
Domoticz
Is there a way i also get it this way on my iphone?
Maybe remove the header and only show the message
Pushbullet
drmabuse71
Re: Pushbullet notification only show header
Post by drmabuse71 »
Got the same problem,
seems to be a problem with pushbullet,
occured since their latest update.
searched the web but couldn´t find any solution
kleinspr
Post by kleinspr »
Hi I am Hans , from Eindhoven(NL)
Same issue when someone uses a apple watch
the message shows:
PUSHBULLET
with message Domoticz, and not the message it self
And if you are using the iphone, some issue
and if you are opening the pushbullet app you get the real information
najtram
Domoticz version: v4.9700
Post by najtram »
Maybe a solution!!
I had the same issue en noticed the reason for my situation. My issue showed up for notifications triggered from blocky events. In the blocky events I was a bit to lazy to use different texts ;) . When these texts are the same, pushbullet uses the text domoticz as header. When they are different you will receive the header.
So in short: DON'T use the same text twice. :idea:
:arrow: (at least in blocky events in combination with iOS)
RFLink Gateway → 433Mhz/KAKU switches
Z-Wave → Z-Stick Gen5+
ZigBee → ConBee II
Bluetooth → Soma Smart Shades
Opentherm Gateway → Remeha iSense - Tzerra boiler
ESP8266+CC1101 → ITHO ecofan RFT
P1 cable → DSMR 2.2+ Landys +gyr E350
LAN → Enphase Envoy
