problems with re-install and update
curious
Post by curious »
After some problems i decided to reinstall domoticz.
I am running version 2.3530 now.
Under setup-> more options-events however the option to choose between blockly or lua disappeared so I cannot enter a lua script .
Besides that when I check for updates I get the message 'No updates avalilable.
After that I tried an install of the latest stable version. When putting back domoticz.db and starting domoticz I get the message that there are no devices and I first have to install hardware first.
when I enter sudo curl -L install.domoticz,com |sudo bash nothing happens. Only the message that I should run apt-get upgrade after insatlling Domoticz
No new version is installed.
I probably miss a step somewhere. Should I give some command to install the new version ?
Pleez help me out on this because I don't like to begin from scratch.
Thanks in advance
toreandre
Re: problems with re-install and update
Post by toreandre »
Try the curl command without "sudo"
HansieNL
Post by HansieNL »
There's a comma between domoticz and com. Did you make a typo?
Blah blah blah
curious
Post by curious »
Thank you for your answers.
I did a fresh install. And it works fine now.
For my fellow noobs : I first restored my db by copying the db file from backup.
Noting was restored then.
What did help was a restore from menu. :oops: :oops:
NietGiftig
Domoticz version: V3.6224
Post by NietGiftig »
curious wrote: For my fellow noobs : I first restored my db by copying the db file from backup.
Did you stop Domoticz before the copy?
RPI-2 + SSD / ESPEasy Sensors & Switches / Sonoff / RFLink / Action Switches / TP-Link switch / Node-Red / Reacticz
