Raspberry 2 B + Razberry Card V1
bsergiu
Post by bsergiu »
Dear community,
I am trying to install latest Domoticz version on the RPi 2 B with a Razberry board. This works with the ZWave.Me image. I have followed the instructions, including the ones from http://www.vesternet.com/resources/appl ... HiK8WfasUF. Additionally, I have updated all the packages (32 updates).
Domoticz software runs, I can see and use the dashboard. However, after configuring the hardware: OpenZwave USB on the /dev/ttyUSB20, I am stuck. I go into the setup, I refresh, and the software does not see the controller itself. I am trying to add the Fibaro motion sensor, no luck. The LED on the Razberry board does not even light up when trying to add a node (note that both LED of Razberry light up when booting, for 1-2 seconds).
Any hints / ideas of how can I debug this?
Any help appreciated!
Sergiu
stuiow
Domoticz version: 3.6857
Re: Raspberry 2 B + Razberry Card V1
Post by stuiow »
I have this setup and the only difference i see is my Razberry is set to use the dev/ttyAMA0 port.
The Vesternet guide says not to use this, but it does work.
Now setup on a RPI3.
Also using Evohome HGI80, RFXTRX433E and a Aeotec Gen5 stick. Mainly a Gen5 Z-Wave system.
My weather (Davis vantage Pro2) data is obtained by weatherunderground
Now collecting rtl_433 data from Apollo Ultrasonic meter
Blueone
Post by Blueone »
Select the /dev/ttyAMA0 directly in the hardware tab from domotics instead of creating the virual link. Is has changed since jessie.
Harryb17
Post by Harryb17 »
I also have had this problem every since I bought the Razberry. Did you have any luck selecting the AMA0 port from the dropdown?
I have tried selecting AMA0 and creating a symlink and neither make the controller visible.
The only way I can get domoticz to see the razberry is by installing zway then I have to manually stop and remove all the crap that comes with it such as the mongoose server, zbw-connect etc....
I wish I could figure out exactly what part if the zway installation script makes domoticz able to see the razberry!
