Yes that works...I must either have the syntax wrong or a broken plugindutchdevil83 wrote:@blackdog65
Can you try following link in your browser if jou get Json result back? (Fill in your API key)
http://api.wunderground.com/api/api_key ... sbech.json
Domoboard - General Discussions
Moderators: leecollings, wez3
Forum rules
Before posting here, make sure you are using the latest Beta or Stable version.
In order to fix issues or add features these have to be reported on the Domoboard Github pages.
This makes it possible to keep track of issues/features on a centralized place.
Refer to the issue of the github tracker when possible.
This subforum is meant to discuss issues and/or feature requests, or anything else related to Domoboard.
- blackdog65
Re: Domoboard a New Dashboard using Domoticz as backend
CubieTruck Master
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
RasPi slaves
EQ3 MAX!
TKB Sockets
RFXCOM
MySensors
ESPEasy ESP8266-12E
- Domoticz version: latest
Thnx for quick fix, iT is working nowwez3 wrote:This one should be fixed:dutchdevil83 wrote:i`m on develop. Trying to debug in chrome inspector but can`t get it to fix.felix63 wrote:
I think my icons have disappeared from the top tiles. are you running development or master? It might be a bug?
https://github.com/wez3/domoboard/issues/71
Hardware
1x Raspberry Pi
1x Razberry Z-Wave
1x RFXtrx433E
1x Toon
1x GoodWe Solarpanels
2x FGSD-002 Smoke Detector
1x FGBS-001 Binaire Sensor (RFID lezer)
7x FGMS-001 Motion Sensor
3x ZW089 Verzonken Deursensor
7x NC Wallplug
&lots of KaKu stuff
1x Raspberry Pi
1x Razberry Z-Wave
1x RFXtrx433E
1x Toon
7x NC Wallplug
&lots of KaKu stuff
You can try Chrome inspection tool if you can discover which part does not loadblackdog65 wrote:Yes that works...I must either have the syntax wrong or a broken plugindutchdevil83 wrote:@blackdog65
Hardware
1x Raspberry Pi
1x Razberry Z-Wave
1x RFXtrx433E
1x Toon
7x NC Wallplug
&lots of KaKu stuff
1x Raspberry Pi
1x Razberry Z-Wave
1x RFXtrx433E
1x Toon
7x NC Wallplug
&lots of KaKu stuff
In which directory do I have to unzip the plugins?
I can't remember ever having seen entries in Settings - Plugins.
I don't get the 'afvalwijzer' form working
When I add this to the config :
I get error : Error: Zipcode not found and see this URL is hitting in the log:
192.168.111.141 - - [12/Jan/2017 22:08:25] "POST /api?custom=afvalwijzer&zipcode=1234AA&housenr=1 HTTP/1.1" 200 -
That looks correct, but give me an error
If i remove the word 'Thuis' is see the log that the house number is parsed as zipcode and housenr is empty
[[afvalwijzer]]
zipcode = Thuis, 1234AA, 1
Same issue here.bsmeding wrote:I don't get the 'afvalwijzer' form working
Please check if the info is available at www.afvalwijzer.nl
(In my case nothing returns)
- Domoticz version: 3.5837
It could if afvalwijzer uses different classes on different zipcodes... i created the script that it will copy the category class from afvalwijzer so it will now which icon it must use. But if it uses different html and css tags on different zipcodes it is almost impossible to create an front which will work on all zipcodes..dutchdevil83 wrote:Mmm strange... you can check with Chrome Inspector tool for errors when loading the page. In Chrome press (CTRL+SHIFT+J) and check preserve log to follow loading trail. Also could be that you are missing some files in the afvalwijzer plug-in folder. You can try to copy the folder from github...Sateetje wrote:No, no adblocker installed and on different browsers almost the same result (on IOS i've an icon at Plastic verpakkingen).dutchdevil83 wrote:
Do you have a adblocker installed or something? Can you look into your page with multiple devices/browsers ?
Coding this way does give three subsections in the top_titles.dutchdevil83 wrote: If you update domoboard to latest version it now looks at the order you`re items are listed in the config file. It will take that order. Also you can make your top_tiles ordered with titles :
components = top_tiles[1], top_tiles[2], top_tiles[3] [[top_tiles]] [[[1]]] example = 1 [[[2]]] example = 2 [[[3]]] example = 3
But in my case the items do not appear in the way they are listed in the configfile.
(Full fresh install of Domoboard)
Although it looks like I keep on complaining? Almost everything works now and it looks great.
Many thanks! Have a beer on me
after installing Traffic and afvalwijzer plugin, when relaunching domoboard i get first error:
"Error occured during loading imports for the plugin "X": No module named BeautifulSoup
then I delete afval.. same error message pop up for "anwb" : No module name natsort.
It tried git pull in both main and plugins folder without succcess, so I just have to delete them to start domoboard.
Then you need to install BeautifulSoup and Natsort. Try this:jhenrikb wrote:after installing Traffic and afvalwijzer plugin, when relaunching domoboard i get first error:
pip install naturalsort
pip install beautifulsoup4
Hardware
1x Raspberry Pi
1x Razberry Z-Wave
1x RFXtrx433E
1x Toon
7x NC Wallplug
&lots of KaKu stuff
1x Raspberry Pi
1x Razberry Z-Wave
1x RFXtrx433E
1x Toon
7x NC Wallplug
&lots of KaKu stuff
Hi Dutchdevil83,dutchdevil83 wrote:Still work in progress but i`m getting there
Showoff 2/3
I saw in you're images that you have an dimmer/slider for volume, is that an virtual switch? i am searching for a way to control my mpd server's volume. I can do it with my python scripts but an slider is obviously more easy to use for my wife
Yep, made a dummy switch which controls my denon receiver over ip. Also pulls out data out of my denon (json) and update the volume slider when it differs, which happens if the volume has been changed manually. All put in a LUA script.squandor wrote:
Hi Dutchdevil83,
Hardware
1x Raspberry Pi
1x Razberry Z-Wave
1x RFXtrx433E
1x Toon
7x NC Wallplug
&lots of KaKu stuff
1x Raspberry Pi
1x Razberry Z-Wave
1x RFXtrx433E
1x Toon
7x NC Wallplug
&lots of KaKu stuff
How did you manage that there will be fired an program when the dimmer slide changes?dutchdevil83 wrote:Yep, made a dummy switch which controls my denon receiver over ip. Also pulls out data out of my denon (json) and update the volume slider when it differs, which happens if the volume has been changed manually. All put in a LUA script.squandor wrote:
Hi Dutchdevil83,
the switches has an on off action but with an dimmer i can't figure out how to do that
Here the piece of code out of my lua script that controls my receiversquandor wrote: How did you manage that there will be fired an program when the dimmer slide changes?
if devicechanged[RECEIVER_VOLUME] then -- MUTE and VOLUME
if (otherdevices[RECEIVER_VOLUME] == "Off") then
os.execute ("curl http://" .. (DENON_IP) .. "/MainZone/index.put.asp?cmd0=PutVolumeMute%2Fon");
print ("Device:" .. RECEIVER_VOLUME .. " send command Mute = On");
NewLevel = otherdevices_svalues[RECEIVER_VOLUME] - 80 ; -- Apply offset from absolute to relative
NewLevel = math.min(NewLevel, 9.5); -- Top Domoticz Scale
os.execute ("curl http://" .. (DENON_IP) .. "/MainZone/index.put.asp?cmd0=PutVolumeMute%2Foff");
os.execute ("curl http://" .. (DENON_IP) .. "/MainZone/index.put.asp?cmd0=PutMasterVolumeSet/" .. (NewLevel));
print ("Device:" .. RECEIVER_VOLUME .. " send command Mute = Off; Set Volume = " .. NewLevel);
Hardware
1x Raspberry Pi
1x Razberry Z-Wave
1x RFXtrx433E
1x Toon
7x NC Wallplug
&lots of KaKu stuff
1x Raspberry Pi
1x Razberry Z-Wave
1x RFXtrx433E
1x Toon
7x NC Wallplug
&lots of KaKu stuff
Great thank you i will try to put it into action with my mpd serverdutchdevil83 wrote:Here the piece of code out of my lua script that controls my receiversquandor wrote: How did you manage that there will be fired an program when the dimmer slide changes?
Basically the script gets triggered when the switch is used in domoticz " if devicechanged['Name of Dimmer'] then " if it turns to "Off" then its muting my receiver. Otherwise it gets the value from the dimmer " otherdevices_svalues['Name of Dimmer'] " and set that level to the receiver. (after doing some mathematical things to get the value correct for my receiver)Code: Select all
if devicechanged[RECEIVER_VOLUME] then -- MUTE and VOLUME if (otherdevices[RECEIVER_VOLUME] == "Off") then os.execute ("curl http://" .. (DENON_IP) .. "/MainZone/index.put.asp?cmd0=PutVolumeMute%2Fon"); print ("Device:" .. RECEIVER_VOLUME .. " send command Mute = On"); else NewLevel = otherdevices_svalues[RECEIVER_VOLUME] - 80 ; -- Apply offset from absolute to relative NewLevel = math.min(NewLevel, 9.5); -- Top Domoticz Scale os.execute ("curl http://" .. (DENON_IP) .. "/MainZone/index.put.asp?cmd0=PutVolumeMute%2Foff"); os.execute ("curl http://" .. (DENON_IP) .. "/MainZone/index.put.asp?cmd0=PutMasterVolumeSet/" .. (NewLevel)); print ("Device:" .. RECEIVER_VOLUME .. " send command Mute = Off; Set Volume = " .. NewLevel); end
Similar to you, also use MPD with airplay speakers, heres an extract from my script for volume using a dummy dimmersquandor wrote:Hi Dutchdevil83,dutchdevil83 wrote:Still work in progress but i`m getting there
Showoff 2/3
-----Volume
if (devicechanged['Radio Volume']) then
v = otherdevices_svalues['Radio Volume']
os.execute('mpc volume ' ..v)
print("radio volume " ..v)
Jep fixed it to. but my mpd server is on an other raspberry.fergalom wrote:Similar to you, also use MPD with airplay speakers, heres an extract from my script for volume using a dummy dimmersquandor wrote:Hi Dutchdevil83,dutchdevil83 wrote:Still work in progress but i`m getting there
Showoff 2/3
-----Volume if (devicechanged['Radio Volume']) then v = otherdevices_svalues['Radio Volume'] os.execute('mpc volume ' ..v) print("radio volume " ..v) end
this is my final lua code and it works like a charm thank you guys
Volume = 'Volume';
if devicechanged[Volume] then -- MUTE and VOLUME
if (otherdevices[Volume] == "Off") then
os.execute ("python /home/pi/domoticz/scripts/SetVolumeMPD.py 0");
print ("Device:" .. Volume .. " send command Mute = On");
NewLevel = otherdevices_svalues[Volume] ; -- Apply offset from absolute to relative
os.execute ("python /home/pi/domoticz/scripts/SetVolumeMPD.py " .. (NewLevel));
print ("Device:" .. Volume .. " send command Mute = Off; Set Volume = " .. NewLevel);
i also managed with an python script to check if there are new airplay speakers in the mpd server it will add them to domoticz with an on/off action already filled in to activate them so if you're interestedfergalom wrote:Similar to you, also use MPD with airplay speakers, heres an extract from my script for volume using a dummy dimmersquandor wrote:Hi Dutchdevil83,dutchdevil83 wrote:Still work in progress but i`m getting there
Showoff 2/3
@squandor Definitely interested in seeing that.
- Domoticz version: 4.10915
I am on Development branche trying to get Wunderground to work.
In conf
Results in no weather displayed - in log :
Mismatch of arguments into api call??
In conf
[weer]
[[display_components]]
components = wunderground[condition], wunderground[forecast]
[[wunderground]]
[[[condition]]]
location = Lelystad
[[[forecast]]]
location = Lelystad
"POST /api?custom=wunderground&loc=condition&country=&action=Lelystad HTTP/1.1" 200 -
"POST /api?custom=wunderground&loc=forecast&country=&action=Lelystad HTTP/1.1" 200 -
