Domoboard - General Discussions
Domoboard is a dashboard for Domoticz based on Python Flask.
Moderators: leecollings, wez3
Forum rules
Before posting here, make sure you are using the latest Beta or Stable version.
In order to fix issues or add features these have to be reported on the Domoboard Github pages.
This makes it possible to keep track of issues/features on a centralized place.
Refer to the issue of the github tracker when possible.
This subforum is meant to discuss issues and/or feature requests, or anything else related to Domoboard.
dutchdevil83
Domoticz version: latest
Re: Domoboard a New Dashboard using Domoticz as backend
Post by dutchdevil83 »
squandor wrote:
dutchdevil83 wrote:
squandor wrote:Just fixed the issue with an ' mark in an name for wunderground.
It has been pulled to the master branch of the plugins so you should see an update button in the settings menu.
`s-Hertogenbosch still not working with version 0.2 ... Just tried with Rosmalen and this works. Anyway to delete text "Condition-Location- .." :?:
i think that you must put 's-hertogenbosch in quotes: "'s-hertogenbosch" than it will work.
Sure. i was struggeling with the title if i should add the action to it. but i can change it so it will only show the city name if you want it.
Thanx! That did the trick :D
Hardware
1x Raspberry Pi
1x Razberry Z-Wave
1x RFXtrx433E
1x Toon
1x GoodWe Solarpanels
2x FGSD-002 Smoke Detector
1x FGBS-001 Binaire Sensor (RFID lezer)
7x FGMS-001 Motion Sensor
3x ZW089 Verzonken Deursensor
7x NC Wallplug
&lots of KaKu stuff
dutchdevil83
Still work in progress but i`m getting there :D
Showoff 1/3
Dashboard
Dashboard
Downstairs
Downstairs
1st Floor
1st Floor
Hardware
1x Raspberry Pi
1x Razberry Z-Wave
1x RFXtrx433E
1x Toon
7x NC Wallplug
&lots of KaKu stuff
dutchdevil83
Showoff 2/3
Attic
Attic
Outside
Outside
Multimedia
Multimedia
Hardware
1x Raspberry Pi
1x Razberry Z-Wave
1x RFXtrx433E
1x Toon
7x NC Wallplug
&lots of KaKu stuff
dutchdevil83
Showoff 3/3
Systemcheck
Systemcheck
Calender
Calender
Hardware
1x Raspberry Pi
1x Razberry Z-Wave
1x RFXtrx433E
1x Toon
7x NC Wallplug
&lots of KaKu stuff
Routernl
Post by Routernl »
Looking good !
Did you manage to get the traffic working with Google maps ?I'm still struggling with that.
dutchdevil83
Routernl wrote:Looking good !
Well it shows a route with traffic jams and/or
Speeding cams....
Altough not a map with traffic update. Will look into this tomorrow
Hardware
1x Raspberry Pi
1x Razberry Z-Wave
1x RFXtrx433E
1x Toon
7x NC Wallplug
&lots of KaKu stuff
Sateetje
Post by Sateetje »
My "afvalwijzer" on the left looks different. How do I get the nice icons?
dutchdevil83
Looking at my pages i see that i don`t have the icons displayed in the top_tiles. Anyone knows why this isn`t loading? The icons on the right navbar is loading properly so i think the font file is correct.
This is the config file for dashboard:
[dashboard]
  [[display_components]]
    components = top_tiles[Temperaturen], top_tiles[Deuren], top_tiles[Status], top_tiles[Verbruik], wunderground[condition], switches[Scenes], camera[Voordeur], news
  [[top_tiles]]
	[[[Temperaturen]]]
		Buiten = 12, thermometer
		Woonkamer = 116, thermometer
		Schuur = 160, thermometer
		Hal (voor) = 173, thermometer
		Badkamer = 237, thermometer
	[[[Deuren]]]
	Voordeur = 201, info
	Deur Hal (voor) = 139, info
	Deur Toilet = 123, info
	Achterdeur = 176, info
	Schuur = 197, info
	Deur Badkamer = 145, info
	[[[Beweging]]]
	PIR Hal Voor = 170, eye
	PIR Toilet = 472, eye
	PIR Traphal  = 501, eye
	PIR Voordeur = 579, eye
	PIR Schuur = 181, eye
	PIR Badkamer = 236, eye
	PIR Voorzolder = 506, eye
	[[[Status]]]
		Alarm = 207, unlock
		Iemand thuis = 148, user-circle
		Rookmelder Woonkamer = 89
		Rookmelder Schuur = 304
	[[[Verbruik]]]
		Elektra = 120, flash, CounterToday
		Zonnepanelen = 29, flash, CounterToday
		Gas = 121, flash, CounterToday
Hardware
1x Raspberry Pi
1x Razberry Z-Wave
1x RFXtrx433E
1x Toon
7x NC Wallplug
&lots of KaKu stuff
dutchdevil83
Sateetje wrote:My "afvalwijzer" on the left looks different. How do I get the nice icons?
Do you have a adblocker installed or something? Can you look into your page with multiple devices/browsers ?
Hardware
1x Raspberry Pi
1x Razberry Z-Wave
1x RFXtrx433E
1x Toon
7x NC Wallplug
&lots of KaKu stuff
jhenrikb
Post by jhenrikb »
anyone get their switches showing only lines?
I have two Identical fibaro wall plugs in "Stue"/livingroom" while 1 show on and off, the other is just lined out.
Also the Virtual "hjemme/borte (home/away)" switch shows a line.
"Hus-Varme-Hovedbryter" is also an identical virtual switch, but this works some how.
John
edit: Cant use ÆØÅ and other non-english symbols. updated them in domoticz-end and it worked.
Last edited by jhenrikb on Thursday 12 January 2017 11:45, edited 1 time in total.
felix63
Domoticz version: 2020.1
Post by felix63 »
dutchdevil83 wrote:Looking at my pages i see that i don`t have the icons displayed in the top_tiles. Anyone knows why this isn`t loading? The icons on the right navbar is loading properly so i think the font file is correct.
I think my icons have disappeared from the top tiles. are you running development or master? It might be a bug?
Awst6000
Post by Awst6000 »
@Dutchdevil83:
Looks nice. I'm a little behind in progress ;)
I have a few questions:
- The top_tiles icons on dashboard.jpg look ordered. Is that right? If so, how did you do it?
- How can I get data from Afvalwijzer?
Txs!
dutchdevil83
Awst6000 wrote:@Dutchdevil83:
Txs!
If you update domoboard to latest version it now looks at the order you`re items are listed in the config file. It will take that order. Also you can make your top_tiles ordered with titles :
components = top_tiles[1], top_tiles[2], top_tiles[3]
[[top_tiles]]
[[[1]]]
example = 1
[[[2]]]
example = 2
[[[3]]]
example = 3
Above code will generate 3 lines of top tiles.
For data from afvalwijzer jou have to install Afvalwijzer plugin. If you have updated domoboard you can go to settings and install from there.
Hardware
1x Raspberry Pi
1x Razberry Z-Wave
1x RFXtrx433E
1x Toon
7x NC Wallplug
&lots of KaKu stuff
dutchdevil83
i`m on develop. Trying to debug in chrome inspector but can`t get it to fix.
Hardware
1x Raspberry Pi
1x Razberry Z-Wave
1x RFXtrx433E
1x Toon
7x NC Wallplug
&lots of KaKu stuff
jhenrikb
Post by jhenrikb »
Dutchdevil:
can you share your config and templats folder for inspiration and some bug fixes?
i cant get my wunderground and some other things to look like your page so It would be intresting to see how your set is.
It looks very good :)
John
dutchdevil83
jhenrikb wrote:Dutchdevil:
John
Sure no problem. Only changes i made for publishing is adding PRIVATE for my personal information
[general_settings]
	[[wunderground]]
	api = PRIVATE
	language = NL
  [[server]]
    url = PRIVATEURL:PRIVATEPORT			# IP-address of Domoticz backend
    flask_url = PRIVATEURL:PRIVATEPORT	# Please note: this is the internal IP-address including port of the Domoboard server
    user = <username>			# Username for Domoticz
    password = <password>		# Password for Domoticz
    secret_key = PRIVATE	# A random secret key used for Python authentication
  [[users]]
    Test = test		# Add users for Domoboard here
  [[domoboard]]
    date = True
	time = True                    # True/False: show time in top bar
	google_maps_api_key = PRIVATE	# Google Maps Embed API key
  [[icloud]]
	user = PRIVATE
	password = PRIVATE
  [[anwb]]
	startPoint = "PRIVATE, Den Bosch"
	endPoint = "PRIVATE, Utrecht"
# Add Navbar items here
[navbar]
  [[menu]]
    Dashboard = dashboard, dashboard
    Begane Grond = begane_grond, home
    1e Verdieping = verdieping, home
    Zolder = zolder, home
    Buiten = buiten, bug
	Systeemcontrole = systeem, heartbeat
    Verkeer = verkeer, road
	Kalender = kalender, calendar
#    Flitsers = flitsers
#    Statistics = statistics
#    Server = server
	Multimedia = multimedia, music
    Instellingen = instellingen, wrench
# Each navbar item needs a section. Components specify which components are displayed on the page. Other subsections contain names, Domoticz IDX's and options of the components displayed.
[dashboard]
  [[top_tiles]]
	[[[Temperaturen]]]
	[[[Deuren]]]
	Schuur = 197, info
	[[[Beweging]]]
	[[[Status]]]
		Alarm = 207, unlock
	[[[Verbruik]]]
  [[wunderground]]
	[[[forecast]]]
	location = "'s-hertogenbosch, NL"
	[[[condition]]]
 [[camera]]
	[[[Voordeur]]]
	url = http://PRIVATEURL:PRIVATEPORT/cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=PRIVATE&pwd=PRIVATE
 [[switches]]
 [[[Scenes]]]
	Huiskamerverlichting = 4, group
    Buitenverlichting = 2, group
	Alles uit = 3, group
   [[power_usage]]
		Afdak (voor) = 546, lightbulb-o
		TV Meubel = 558, lightbulb-o
		Dressoir = 585, lightbulb-o
		Achtertuin = 373, lightbulb-o
		Verwarming Schuur = 395, fire
		Badkamer = 300, lightbulb-o
		Slaapkamer = 192, lightbulb-o
		Droger = 538, plug
		Wasmachine = 530, plug
  [[weather]]
    Location = "Den Bosch, NB"
  [[map]]
    [[[1]]]
      Location = PRIVATE
    [[[2]]]
      Location = PRIVATE
  [[news]]
	  rssfeed = http://www.omroepbrabant.nl/rss/?feed=homepage
    # rssfeed = http://www.nu.nl/rss/Algemeen
[begane_grond]
    components = top_tiles[Temperaturen],top_tiles[Deuren], top_tiles[Beweging], switches[Schakelaars]
  [[top_tiles]]
	[[[Temperaturen]]]
	[[[Deuren]]]
	Schuur = 197, info
	[[[Beweging]]]
  [[switches]]
  [[[Schakelaars]]]
	TOON = 115, setpoint
	Hal (voor) = 342, switch
	TV Meubel = 553, switch
	Dressoir = 580, switch
	Keukenkasten = 162, switch
	Traphal = 389, switch
	Toilet = 98, switch
	Schuur = 345, switch
	Verwarming Schuur = 210, switch
[verdieping]
    components = top_tiles[Badkamer], top_tiles[Slaapkamer], switches
 [[top_tiles]]
	[[[Badkamer]]]
	Temp Badkamer = 237, thermometer
	[[[Slaapkamer]]]
 [[switches]]
	Badkamer = 347, switch
	Slaapkamer = 184, dimmer
  [zolder]
    components = top_tiles, domoticz_smart_charts[1], domoticz_smart_charts[2]
	[[top_tiles]]
	Droger = 538, plug
 [[domoticz_smart_charts]]
	[[[1]]]
	Wasmachine = 529, week, energy
	[[[2]]]
	Droger = 537, month, energy
[buiten]
    components = top_tiles[Weer], top_tiles[Status], wunderground[forecast], buienradar, switches, power_usage
  [[top_tiles]]
	[[[Weer]]]
		Temperatuur = 12, thermometer
		Regen Actueel = 14, shower, percent
  [[wunderground]]
	[[[forecast]]]
	[[[condition]]]
	[[[Status]]]
		Buitenlamp Schuur = 402, lightbulb-o
		Afdak voor = 541, lightbulb-o
		Afdak achter = 343, lightbulb-o
		Achtertuin = 398, lightbulb-o
 [[switches]]
    Buitenlamp Schuur = 402, switch
	Afdak voor = 541, switch
	Afdak achter = 343, switch
	Achtertuin = 398, switch
[kalender]
 components = afvalwijzer, icloud
 [[icloud]]
 [[afvalwijzer]]
  zipcode = PRIVATECODE, HOUSENUMBER
[multimedia]
    components = top_tiles, switches, tvgids
	[[top_tiles]]
	Denon = 588, film
	Denon Volume = 589, volume-up
	# Denon Status = 566, info
	[[switches]]
	Versterker = 25, switch
	Volume = 564, dimmer
	Subwoofer = 102, switch
[verkeer]
    components = anwb, verkeer
	[[anwb]]
	[[verkeer]]
[systeem]
    components = top_tiles[1], top_tiles[Zonnepanelen], switches[Wake-On-LAN], power_usage, serverlog
 [[top_tiles]]
 [[[1]]]
Eneco Toon = 407, sun-o
Horizon Box = 409, film
iPhone Chantal WiFi = 256, apple
iPhone Marco WiFi = 264, apple
Labelprinter POSTNL Schuur = 272, print
Labelprinter Schuur = 271, print
Laptop Schuur = 561, laptop
NAS = 279, server
PC Zolder = 212, desktop
Printer Schuur = 268, print
Tapwater  Aan = 118, shower
Verwarmen Aan = 117, fire
Voorverwarmen Aan = 119, fire
Ziggo Modem = 273, wifi
 [[[Zonnepanelen]]]
Zonnepanelen = 406, plug, CounterToday
Zonnepanelen (Volt) = 405, flash
Zonnepanelen (Temp) = 404, thermometer
Zonnepanelen (Eff) = 403, percent
Zonnestraling = 79, sun-o
Zonnepanelen Status = 30, info
Zonnepanelen Fout = 31, info
 [[switches]]
 [[[Wake-On-LAN]]]
 Laptop Schuur = 561, pushon
 NAS = 279, pushon
 PC Zolder = 212, pushon
 [[power_usage]]
[instellingen]
    components = settings
Hardware
1x Raspberry Pi
1x Razberry Z-Wave
1x RFXtrx433E
1x Toon
7x NC Wallplug
&lots of KaKu stuff
GuyTreepbush
Post by GuyTreepbush »
I saw some people asking if this could run on a Synology. I tried today and for me the answer is yes.
With SSH (you need root acces and need to install easy_install if you do not have so) first install the depencies.
Rather than using GIT I just downloaded the package. Copied the files to my home directory but can be anywhere.
Change the config file and with SSH go the folder with the files in them. Using the command line, start the service as specified in the readme file. The port wil be the one you specified in the config file so make certain it is not in use already on your synology.
Then I was able to go to the url it worked!
well... sort of:
- I only specified 2 switches. 1 worked and one had the wrong type.
- Half of the links gave a 404
- I could see the log of my domoticz server but the settings tab does not do much
- the location tile worked only a fraction of the time
- How do I turn of logging in?
but all that stuff probably is trial and error and investigating this thread and the documentation.
dutchdevil83
Here are some pictures from my wall mounted tablet (click on picture for big version):
Image Image
As you can see top tiles needs some work to fit properly. Maybe smaller text or other font?
Hardware
1x Raspberry Pi
1x Razberry Z-Wave
1x RFXtrx433E
1x Toon
7x NC Wallplug
&lots of KaKu stuff
Awst6000
Post by Awst6000 »
- How do I get the date in the header without a click on the time? I do have time=True and date=true in the config.file.
- Is it possible to translate the words shown in the top_tiles? Like open/dicht/aan/uit. Or can they be replaced by icons that show the status?
- Maybe put in other useful info in the header? Like Domoticz which has Sunrise and sunset in the header.
Txs
dutchdevil83
Awst6000 wrote:Hi,
Txs
1) Do you have true spelled with a capital T in your config? If you look into my config above you see a config which should work
2) No not yet. I have opened a issue on github to make a variables file which can support local language
Hardware
1x Raspberry Pi
1x Razberry Z-Wave
1x RFXtrx433E
1x Toon
7x NC Wallplug
&lots of KaKu stuff
