problems with Persistent data [SOLVED]
gus
Post by gus »
I'm trying to work with Persistent data, but for some reason I don't get it to work the way that I want to.
Even if barometer_old contains the same value (980) as presented in barometer the if state triggers.
This is my code, please advice a LUA dummies...
        data = {
        barometer_old = {},
		if (barometer) ~= (barometer_old) then
			domoticz.devices['Trigger request Text 2_1'].switchOn()
			domoticz.data.barometer_old = (barometer)
Egregius
Domoticz version: v2024.7
Re: problems with Persistent data
Post by Egregius »
Are you sure both values are the same?
I know that for example a setpoint sometimes returns 1 decimal place, and sometimes 2. Like 21.0 and 21.00.
If you then compare that as a string they are different.
I also think you should post the complete code...
gus
Post by gus »
Ok, some complements!
This is th values from my log:
2017-01-11 17:12:00.942 LUA: barometer_old value: 976
2017-01-11 17:12:00.943 LUA: barometer value: 976
This is my code:
-- Hantering av display				 --
        active = true,
        ['timer'] = {'every minute'}
        data = {
        barometer_old = {},
    execute = function(domoticz)
		local function roundToNthDecimal(num, n)
			local mult = 10^(n or 0)
			return math.floor(num * mult + 0.5) / mult
		local barometer = roundToNthDecimal((domoticz.devices['Barometer'].barometer), 0)
		local balja = roundToNthDecimal((domoticz.devices['Temp to Pool'].temperature), 1)
		local utetemp = roundToNthDecimal((domoticz.devices['Temp Veranda Ute'].temperature), 1)
		local vindgust = roundToNthDecimal((domoticz.devices['Wind'].windgust), 1)
		local regn = roundToNthDecimal((domoticz.devices['Rain'].rain), 1)
		domoticz.log(('barometer_old value: ') .. (domoticz.data.barometer_old))
		domoticz.log(('barometer value: ') .. (barometer))
		domoticz.devices['Text 1_1'].updateText('Klockan ar ' .. os.date("%R"))
		domoticz.devices['Trigger request Text 1_1'].switchOn()
		domoticz.devices['Text 3_1'].updateText('Temp Balja  ' .. (balja) .. ' Grader')
		domoticz.devices['Trigger request Text 3_1'].switchOn()
		domoticz.devices['Text 4_1'].updateText('Utetemp ar  ' .. (utetemp) .. ' Grader')
		domoticz.devices['Trigger request Text 4_1'].switchOn()
		if domoticz.devices['Lockstatus'].state == 'Closed' then
			domoticz.devices['Text 5_1'].updateText('Alla dorrar ar lasta')
			domoticz.devices['Trigger request Text 5_1'].switchOn()
		else domoticz.devices['Text 5_1'].updateText('Nagot ar oppet!')
		if (vindgust) <= 2 then
			domoticz.devices['Text 6_1'].updateText('Det ar vindstilla')
			domoticz.devices['Trigger request Text 6_1'].switchOn()
		elseif (vindgust) >= 3 then
			domoticz.devices['Text 6_1'].updateText('Det blaser nu ' .. (vindgust) .. ' m/s')
		if (regn) == 0 then
			domoticz.devices['Text 7_1'].updateText('Inget regn idag!')
			domoticz.devices['Trigger request Text 7_1'].switchOn()
		elseif (regn) > 0 then
			domoticz.devices['Text 7_1'].updateText('Det har regnat ' .. (regn) .. ' mm idag')
		if (domoticz.time.hour) >= 0 and (domoticz.time.hour) <= 4 then
			domoticz.devices['Text 8_1'].updateText('Natti Natti!')
			domoticz.devices['Trigger request Text 8_1'].switchOn()
		elseif (domoticz.time.hour) >= 5 and (domoticz.time.hour) <= 9 then
			domoticz.devices['Text 8_1'].updateText('God Morgon!')
		elseif (domoticz.time.hour) >= 10 and (domoticz.time.hour) <= 16 then
			domoticz.devices['Text 8_1'].updateText('God Dag!')
		elseif (domoticz.time.hour) >= 17 and (domoticz.time.hour) <= 23 then
			domoticz.devices['Text 8_1'].updateText('God Afton!')
elmortero
Domoticz version: 3.9639
Post by elmortero »
I don't know if it is compulsary, but I always give an initial value, even if It is nil.
That is how is described on the dzvents github page
Verstuurd vanaf mijn SM-G903F met Tapatalk
gus
Post by gus »
elmortero wrote:I don't know if it is compulsary, but I always give an initial value, even if It is nil.
That was included in my first code, but when it didn't work, I'll tried to take it away.
elmortero
Post by elmortero »
In that case I wouldn't know.
This is a working script I use that is similar to what you want, maybe you find something that can help you
	active = true,
		['timer'] = 'every 30 minutes'
	    data = {
        prevtbath = {initial=15}
		local tempd   = domoticz.devices['Temp_bathroom']
		local prevt = domoticz.data.prevtbath
		local diffd = domoticz.devices['bathdiff']
		local precurrtemp = tempd.temperature
		local idp = 2
		local mult = 10^(idp or 0)
		local precurrtemp	= tonumber(tempd.temperature)
		local diff = tonumber(precurrtemp - prevt)
		local currtemp = math.floor(precurrtemp * mult +0.5) / mult
		local diffround = math.floor(diff * mult +0.5) / mult
		diffd.updateTemperature(diffround)
				domoticz.log('Current temperature in bathroom is ' .. currtemp, domoticz.LOG_INFO)
				domoticz.log('previous temperature in bathroom was ' .. prevt, domoticz.LOG_INFO)
		domoticz.log('Difference is ' .. diffround, domoticz.LOG_INFO)
        domoticz.data.prevtbath = currtemp
gus
Post by gus »
elmortero wrote:In that case I wouldn't know.
	active = true,
	    data = {
		local idp = 2
Yes, thank you!
I found the problem, you can not use Persistent data directly. When I created a local variable as you did, then it worked!
Doler
Re: problems with Persistent data [SOLVED]
Post by Doler »
It would already have worked if you had changed
into
if (barometer) ~= (domoticz.data.barometer_old) then
. No special need to put it into a local variable other than nicer code.
Mark: Domoticz latest Beta on Virtual machine (Proxmox) running Debian Bookworm - Z-Stick 7 - RFXCom - P1 - SolarEdge - Dahua - Philips Hue - Docker - Zigbee2mqtt (latest, docker) via python plugin - Zwave-js-ui (latest, docker) - dzVents - Nodered
gus
Post by gus »
Doler wrote:It would already have worked if you had changed
into
Correct, thx!
