Domoboard - General Discussions
Domoboard is a dashboard for Domoticz based on Python Flask.
Moderators: leecollings, wez3
Forum rules
Before posting here, make sure you are using the latest Beta or Stable version.
In order to fix issues or add features these have to be reported on the Domoboard Github pages.
This makes it possible to keep track of issues/features on a centralized place.
Refer to the issue of the github tracker when possible.
This subforum is meant to discuss issues and/or feature requests, or anything else related to Domoboard.
wez3
Re: Domoboard a New Dashboard using Domoticz as backend
Post by wez3 »
apt80 wrote:
bsmeding wrote: try install the Auth python moduel :
pip install auth
Yeah, thanks for the advice.
I did so. At first auth wouldn't install because of errors, not sure what exactly
I tried > sudo easy_install auth
Then > sudo pip install auth
which failed as well. Then I figured I need to install the python build tools to install auth. That worked.
After > sudo apt-get install build-essential python-dev
I was able to install auth with > sudo pip install auth
But it didn't solve the missing auth package error. Finally I tried this:
sudo easy_install flaskex Flask-OAuth2-Login Flask-OAuth Flask-ExtDirect Flask-Auth Flask-Login
Because of an earlier suggestion. But to no avail...
Some people suggested that the auth module has some problems on the "full" raspbian jessie. You might try raspbian jessie lite, some people said that works. I've already created an issue on this on github. I will check it when i am able to. If you try it, can you tell me whether it worked :)?
Routernl
Post by Routernl »
I really like the domoboard, many thnx for creating and sharing !
Configuring through the .conf file is a very nice setup, and most of the options are self-explanatory, the board and google supply most of the necessary answers, but the Google maps I can't figure out..
Is anyone else experiencing an empty maps panel ?
I've tried filling in locations in the conf file (and filled in an API for Google maps embedded) but as a result I only get a blank panel .
On inspection chrome reports the following error :
Uncaught TypeError: Cannot read property '0' of undefined at domoboard.js:128
line 128 in domoboard.js reads:
var locurl = "https://www.google.com/maps/embed/v1/place?key=" + googleMapEmbedKey + "&q=" + encodeURIComponent(data.result[0].Data) + "&maptype=satellite";
As I am neither a coder nor a js I'm at a loss..
Anyone got this working ?
wez3
Post by wez3 »
Routernl wrote:I really like the domoboard, many thnx for creating and sharing !
You have to fill in a IDX from domoticz (text utility) that contains your location.
felix63
Domoticz version: 2020.1
Post by felix63 »
Demoboard doesn't work anymore. I get the following. I don't understand. Its either because of the git pull I just did or because of my attempts to update python-six...!?
pi@domus:~/domoboard$ python server.py -c basic.conf
 * Running on http://192.168.178.50:8008/ (Press CTRL+C to quit)
[2017-01-09 22:24:12,847] ERROR in app: Exception on /dashboard [GET]
  File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 1982, in wsgi_app
    response = self.full_dispatch_request()
  File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 1614, in full_dispatch_request
    rv = self.handle_user_exception(e)
  File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 1517, in handle_user_exception
    reraise(exc_type, exc_value, tb)
  File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 1612, in full_dispatch_request
    rv = self.dispatch_request()
  File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 1598, in dispatch_request
    return self.view_functions[rule.endpoint](**req.view_args)
  File "/usr/local/lib/python2.7/dist-packages/Flask_Auth-0.85-py2.7.egg/flaskext/auth/auth.py", line 186, in decorator
    return func(*args, **kwargs)
  File "server.py", line 50, in generatePage
    debug = app.debug)
  File "/usr/local/lib/python2.7/dist-packages/flask/templating.py", line 134, in render_template
    context, ctx.app)
  File "/usr/local/lib/python2.7/dist-packages/flask/templating.py", line 116, in _render
    rv = template.render(context)
  File "/usr/local/lib/python2.7/dist-packages/Jinja2-2.9.3-py2.7.egg/jinja2/environment.py", line 1008, in render
    return self.environment.handle_exception(exc_info, True)
  File "/usr/local/lib/python2.7/dist-packages/Jinja2-2.9.3-py2.7.egg/jinja2/environment.py", line 780, in handle_exception
  File "/home/pi/domoboard/templates/index.html", line 7, in top-level template code
    {% include k + ".html" ignore missing %}
  File "/home/pi/domoboard/templates/switches.html", line 18, in top-level template code
    {% for k, v in blockArray[count]["switches"].iteritems() %}
  File "/usr/local/lib/python2.7/dist-packages/Jinja2-2.9.3-py2.7.egg/jinja2/environment.py", line 430, in getattr
    return getattr(obj, attribute)
UndefinedError: 'collections.OrderedDict object' has no attribute 'switches'
192.168.178.29 - - [09/Jan/2017 22:24:12] "GET /dashboard HTTP/1.1" 500 -
squandor
Domoticz version: 3.5837
Post by squandor »
felix63 wrote:Demoboard doesn't work anymore. I get the following. I don't understand. Its either because of the git pull I just did or because of my attempts to update python-six...!?
    debug = app.debug)
    context, ctx.app)
that's strange it still works with our test situations. we did fixed 3 issues with one change so maybe it's that i will ask Wez3 tomorrow.
Awst6000
Post by Awst6000 »
Yesterday I downloaded the lastest version of Domoboard and I also got a lot of errors, even when using the same .conf file from another configuration that does work without problems.
It looks as if Domoboard is very strict now in syntax.
jhenrikb
Post by jhenrikb »
Thanks Squandor. That fixed the issue.
I spent the morning editing the conf file, removing and adding IDX's etc.
I typed in my IP and port to Domoticz backend, and used the same IP with a different port on domoboard.
I start up the file, go to login page and type in the username and password that is written in the config file.
It gives me a "bad request" page in chrome after i logged in.
putty log shows:
192.168.1.111 - - [10/Jan/2017 11:07:27] "GET /login/static/js/moment.min.js HTTP/1.1" 404 -
192.168.1.111 - - [10/Jan/2017 11:07:53] "POST /login/ HTTP/1.1" 400 -
heres my config file if anyone wonder
domob.zip
conf file
(1.45 KiB) Downloaded 49 times
Sincerely
John
squandor
Post by squandor »
Awst6000 wrote:Hi,
I Awst6000 how does you're config looks like and which kind of error did you get?
Felix82
Post by Felix82 »
Snowtiger wrote:
Snowtiger wrote:I installed all dependencies but still get this error :
xx@raspberrypi:~/git/domoboard $ sudo python2.7 server.py -c myconf.conf
  File "server.py", line 4, in <module>
    from flaskext.auth import Auth, AuthUser, login_required, logout
ImportError: No module named auth
As you can see i already did the python2.7 trick - also tried to install auth via easy-install but that did not solve the error.
I have been digging around - running on a Pi with Raspbian Jessie, python2.7 info
Python 2.7.9 (default, Sep 17 2016, 20:26:04)
[GCC 4.9.2] on linux2
I have checked the sys.path if everything is included
['', '/usr/lib/python2.7/dist-packages', '/usr/local/lib/python2.7/dist-packages/Flask_Auth-0.85-py2.7.egg', '/usr/local/lib/python2.7/dist-packages/configobj-5.0.6-py2.7.egg', '/usr/local/lib/python2.7/dist-packages/GitPython-2.1.1-py2.7.egg', '/usr/local/lib/python2.7/dist-packages/gitdb2-2.0.0-py2.7.egg', '/usr/local/lib/python2.7/dist-packages/smmap2-2.0.1-py2.7.egg', '/usr/local/lib/python2.7/dist-packages/simplejson-3.10.0-py2.7-linux-armv7l.egg', '/usr/local/lib/python2.7/dist-packages/bleach-1.5.0-py2.7.egg', '/usr/lib/python2.7', '/usr/lib/python2.7/plat-arm-linux-gnueabihf', '/usr/lib/python2.7/lib-tk', '/usr/lib/python2.7/lib-old', '/usr/lib/python2.7/lib-dynload', '/usr/local/lib/python2.7/dist-packages', '/usr/lib/python2.7/dist-packages/gtk-2.0', '/usr/lib/pymodules/python2.7']
looks alright to me, running direct in command line Python -
  File "<stdin>", line 1, in <module>
Shoot me maar lek ;)
Tot zover - iemand met Phyton kennis nog enig idee?
FYI
Im', running a Pi3, Full Jessie (11-2016). I also encountered the same error message after running server.py ("No module named auth").
I got rid of the message by running these commands:
Sudo pip install auth --upgrade
Sudo easy_install requests
Sudo easy_install auth
After running these commands i got the Idx "bla" is not... # them out in de .conf file
By solving this, a new one has appeared :)
File "server.py", line 156, in <module>
auth = Auth(app, login_url_name='login_form')
NameError: name 'Auth' is not defined
jhenrikb
Post by jhenrikb »
went over my config again. Now after login it shows "Internal server error"
Raspbian command window show
pi@raspberrypi:~/domoboard $ python server.py -c domob.conf
* Running on http://192.168.1.127:8090/ (Press CTRL+C to quit)
192.168.1.111 - - [10/Jan/2017 13:26:17] "GET /login/ HTTP/1.1" 200 -
192.168.1.111 - - [10/Jan/2017 13:26:17] "GET /login/static/js/moment.min.js HTTP/1.1" 404 -
192.168.1.111 - - [10/Jan/2017 13:26:36] "POST /login/ HTTP/1.1" 200 -
192.168.1.111 - - [10/Jan/2017 13:26:36] "GET /login/static/js/moment.min.js HTTP/1.1" 404 -
192.168.1.111 - - [10/Jan/2017 13:26:47] "POST /login/ HTTP/1.1" 302 -
[2017-01-10 13:26:47,354] ERROR in app: Exception on /dashboard [GET]
File "/usr/local/lib/python2.7/dist-packages/Flask-0.12-py2.7.egg/flask/app.py", line 1982, in wsgi_app
File "/usr/local/lib/python2.7/dist-packages/Flask-0.12-py2.7.egg/flask/app.py", line 1614, in full_dispatch_request
File "/usr/local/lib/python2.7/dist-packages/Flask-0.12-py2.7.egg/flask/app.py", line 1517, in handle_user_exception
File "/usr/local/lib/python2.7/dist-packages/Flask-0.12-py2.7.egg/flask/app.py", line 1612, in full_dispatch_request
File "/usr/local/lib/python2.7/dist-packages/Flask-0.12-py2.7.egg/flask/app.py", line 1598, in dispatch_request
File "server.py", line 48, in generatePage
_csrf_token = session['_csrf_token'])
File "/usr/local/lib/python2.7/dist-packages/Flask-0.12-py2.7.egg/flask/templating.py", line 134, in render_template
context, ctx.app)
File "/usr/local/lib/python2.7/dist-packages/Flask-0.12-py2.7.egg/flask/templating.py", line 116, in _render
File "/home/pi/domoboard/templates/line_charts.html", line 29, in top-level template code
{% for k, v in blockArray[count]["line_charts"].iteritems() %}
UndefinedError: 'dict object' has no attribute 'line_charts'
192.168.1.111 - - [10/Jan/2017 13:26:47] "GET /dashboard HTTP/1.1" 500 -
Is it normal for it to show a different IP?
John
Awst6000
Post by Awst6000 »
I also got a lot of these errors that look like this (has no attribute 'line_charts')
It seems that you cannot have empty entries.
This is only an example !!!
[info]
[[display_components]]
components = top_tiles, tvgids, news
[[top_tiles]]
[[tvgids]]
<no news entry>
squandor
Post by squandor »
Awst6000 wrote:Hi,
[info]
[[top_tiles]]
[[tvgids]]
<no news entry>
Thats Right, you can't because you set news in components the server looks for an [[news]] item in the list.
dutchdevil83
Domoticz version: latest
Post by dutchdevil83 »
I have pulled the develop branch but still have some issues configuring domoboard. Can someone tell me if the functions are supported and how to use it?
1) Can`t get CounterToday values from my P1 Meters (gas+electricity)... It only displays the total usage (first value from the DATA string ). looks like it doesn`t get CounterToday from JSON string?
2) Can`t get current usage from P1 Meter (USAGE from JSON string)
3) Is it possible to display only temp, only humidity, only baro, etc from 1 sensor. For example for my weather sensor it display temp+humidity+baro but all those data doesn`t fit in the top tile
If i know this are issues then i can register them at github if necessary
Hardware
1x Raspberry Pi
1x Razberry Z-Wave
1x RFXtrx433E
1x Toon
1x GoodWe Solarpanels
2x FGSD-002 Smoke Detector
1x FGBS-001 Binaire Sensor (RFID lezer)
7x FGMS-001 Motion Sensor
3x ZW089 Verzonken Deursensor
7x NC Wallplug
&lots of KaKu stuff
felix63
Post by felix63 »
jhenrikb wrote:went over my config again. Now after login it shows "Internal server error"
Hi John,
I have the same problems as you. Did you recently updated your system (sudo apt-get update/upgrade)? Or did you reinstall some of the dependencies?
Cheers,
Lex
felix63
Post by felix63 »
I restored my SD-card to the previous version (on which i initially installed a working version of Domoboard).
Did
sudo apt-get install python-setuptools
sudo easy_install flask flask-auth configobj gitpython simplejson bleach requests
git clone https://github.com/wez3/domoboard
and I am still getting the same errors when calling domoboard. So now I'm sure it's not me :)
dutchdevil83
This is fixed by adding the following code : then the onclick function on ipad will loading in same window instead of opening safari when de dashboard is running from the Homescreen as 'native' app
var a=document.getElementsByTagName("a");
for(var i=0;i<a.length;i++)
    a[i].onclick=function()
        window.location=this.getAttribute("href");
        return false
Where do i have to put this code?
Can you make a pull request for this issue on github?
Hardware
1x Raspberry Pi
1x Razberry Z-Wave
1x RFXtrx433E
1x Toon
7x NC Wallplug
&lots of KaKu stuff
squandor
Post by squandor »
Make sure to use master if you are looking for stability. The development branch is used for testing and development which could contain bugs (however we would like to know them!).
Awst6000
Post by Awst6000 »
squandor wrote:Make sure to use master if you are looking for stability. The development branch is used for testing and development which could contain bugs (however we would like to know them!).
Yesterday It was surely the master branch I downloaded. (The zipfile also contains the word 'master')
I recognize a lot of the errors in the posts above.
I'm not a coder but maybe it is wise to rollback the recent changes.
jhenrikb
Post by jhenrikb »
Hi John,
Cheers,
Lex
Heya, yeah. Everything is the newest version from fresh install.
I can't even install a simple Frontpage from this forum even though I do everything right (or so I believe :p). Load in IP etc but nothing works. Domoticz offline all the time. If I upload the Frontpage on my computer and get the idxs from the Pi3 it's working perfectly. I will try to install domoboard on Windows later and see if that works.
John
linconnu76
Domoticz version: 3.4834
Post by linconnu76 »
I've got this problem :
pi@raspberrypi:~/domoboard$ sudo python server.py -c domoboard.conf
* Running on http://192.168.1.9:5000/ (Press CTRL+C to quit)
[2017-01-10 18:49:05,627] ERROR in app: Exception on /dashboard [GET]
context, ctx.app)
File "/usr/local/lib/python2.7/dist-packages/Jinja2-2.9.2-py2.7.egg/jinja2/environment.py", line 1008, in render
File "/usr/local/lib/python2.7/dist-packages/Jinja2-2.9.2-py2.7.egg/jinja2/environment.py", line 780, in handle_exception
File "/home/pi/domoboard/templates/index.html", line 9, in top-level template code
{% set count = count + 1 %}
UndefinedError: 'count' is undefined
What can I do ?
