Since 4 days I have a Problem with an Devolo Thermostat. Everything works ok, only the temperature value is not updatet. The value is correct in the ZWave Operation Panel!
I have discovered a deviation from my other thermostats in the ZWave Operation Panel. There is an additional field: Relative Humidity which does not exist by the others...
But nothing was changed in the system...
Whats going on here
