I have a temperature device connected, working OK.
Now I have one "bad input" , 62 degrees instead of the (here) normal 5 degrees.
This is totally ruining my daily and monthly graph.
Is there a way to remove that sample.
Doesn't need to be from the UI, I know how to get in the system.
Remove one measurement
- Egregius
- Domoticz version: v2024.7
Re: Remove one measurement
Change it in the database or search the forum, lots of posts about this.
- bbqkees
- Domoticz version: 4.1x
To give an actually helpful comment;
Go to the plot/graph of the sensor, press the 'Shift' button on the keyboard and then left-click on the value you want to remove.
hreintke
Thanks,
Works perfect and the solution proved to be much easier than I expected it to be.
Toulon7559
- Domoticz version: <2025
Deletion of a value by Shift+Click works for temperature graphs.
Is a comparable function available for Rainfall (and for similar bargraphs e.g. for Power in section 'Miscellaneous')?
